Old 02-15-2016, 01:42 PM   #1
bunnyc
bunnyc's Avatar
Default Speedometer/odometer/trip meter
Everything works on mine except the trip meter. The reset shaft won't push in and the trip meter doesn't advance.
Is there a written procedure for fixing this anywhere or should I just leave it alone.
BunnyC
bunnyc is offline   Reply With Quote
Old 02-15-2016, 02:01 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Speedometer/odometer/trip meter
It's not hard to remove the cover and lens so you can see what's keeping the knob from pushing back in. I don't know if it can cause damage by moving the knob while the car is moving, but I only reset the miles while at a stop.
Old 02-15-2016, 02:10 PM   #3
bunnyc
bunnyc's Avatar
Thanks Tom. I found the article by Mr. Fischer on restoring the speedo. I'll give it a try.
