Old 12-29-2015, 11:27 AM   #1
wrndln
Default Freeing window regulater handle
I bought a handle for a closed car window regulator at a swap meet recently. However, the knob on the handle does not turn like it should. I soaked the knob end in PB Blaster, but it didn't help. I suspect the knob swelled a little being pot metal. I hate to use heat, as I think it might ruin the handle. Does anyone have a way to allow the knob to turn?
Thanks for any help,
Rusty Nelson
Old 12-29-2015, 11:59 AM   #2
Tim B.
Default Re: Freeing window regulater handle
Put it in a small can knob end down. Fill with your favorite penetrating oil until the knob is covered and put the can on a shelf where you will be able to find it and let it sit. Check it in a month or so. Patience and penetrating oil may be your best tools. Tim
Tim B. is offline   Reply With Quote
Old 12-29-2015, 05:01 PM   #3
SeaSlugs
SeaSlugs's Avatar
^^ yup or acetone and ATF ^^^ stuff creeps into everything.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 12-29-2015, 05:14 PM   #4
Mitch//pa
Put it in a cup of evaporust
Old 12-29-2015, 05:24 PM   #5
C26Pinelake
Great advice Tim ! Patience is your friend in this scenario! Wayne
C26Pinelake is offline   Reply With Quote
Old 12-29-2015, 06:31 PM   #6
wrndln
I am in no hurry, so I think I will do as Tim said, leave it in penetrating oil for about a month. If that doesn't work, go to acetone. If that doesn't work Evaporust.
Thanks for the suggestions.
Rusty Nelson
Old 12-29-2015, 08:39 PM   #7
old car guy
My 29 did not have the handles and I like you bought some and they were the same very stiff did as Mitch suggested and in no time those suckers spun like a raise horse. I am sure the oil and acetone would work also but the evaporust desolated the rust inside the handles, no more problems and it seemed liked they posited up better also.
old car guy
old car guy is offline   Reply With Quote
