Old 12-25-2015, 05:26 PM   #1
Larry Jenkins
Default Project unkown.. 30 CCPU vacuum wiper
I either don't have the right Trico vacuum windshield wiper or I might have the wrong windshield frame. The holes in the frame don't match the wiper I have. So, a request from 30 CCPU owners..
Could you post close-up images of your wiper installation? Most appreciated!
Yes, I have Marco's drawing.
Larry
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 12-25-2015, 06:03 PM   #2
Vin-tin
Vin-tin's Avatar
Default Re: Project unkown.. 30 CCPU vacuum wiper
I'm pretty sure all commercial vehicles, including the pickups, had a hand operated wiper.
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 12-25-2015, 06:34 PM   #3
Pickupman
That information is not correct. Hand wipers were used on commercial vehicles through April 1930. So, Staring in May 1930, pickups used vacuum wipers.
Pickupman is offline   Reply With Quote
Old 12-25-2015, 07:50 PM   #4
Larry Jenkins
Mine is a May, 1930.
Larry
Old 12-25-2015, 06:32 PM   #5
ModelAMike1930
ModelAMike1930's Avatar
Hope this helps.
ModelAMike1930 is offline   Reply With Quote
Old 12-25-2015, 06:37 PM   #6
Vin-tin
Vin-tin's Avatar
My bad. Should have looked it up before stating that. Thanks for correcting me.
1929 Coupe
1930 Coupe
Old 12-27-2015, 07:38 AM   #7
C26Pinelake
You said pretty sure, not absolute! Don't feel bad, a lot worse mistakes have been made on this site. It is not tar and feather time. Wayne
C26Pinelake is offline   Reply With Quote
Old 12-26-2015, 07:09 PM   #8
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Is there a sorta "fits all" electric wiper for my June '29 Coupe?
Bill Rain-X
"THE ASSISTANT GURU OF STUFF"
Old 12-26-2015, 08:07 PM   #9
Brian T
Brian T's Avatar
Not to deter Larry with his vacuum wiper project, reminds me of a crazy idea of installing one in my Double A, memories from years ago of hearing that rhythmic flip flop noise was a facination that was drawing me to a project I would have regretted, however I saw that some cutting, carving and drilling was in order so I ditched that idea, so RainEx it is.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 12-26-2015, 07:30 PM   #10
glenn in camino
glenn in camino's Avatar
Forget the wiper. Get some RainEX.
glenn in camino is offline   Reply With Quote
Old 12-26-2015, 09:13 PM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
My 29 Tudor came with a red plastic wiper motor that is a "fits all" type as used on Cushman Trucksters, and maybe later Jeeps and golf carts with windshields. As I recall, it's made by EA Laboratories.
Old 12-26-2015, 09:29 PM   #12
30aadoodlebug
30aadoodlebug's Avatar
I had a similar issue with a wiper motor that someone gave me a few months ago. The motor worked after I rebuilt it, but it just wouldn't mount to the frame. Come to find out, it was an after market replacement for a 31 Chevy coupe! (If any one knows someone with a 31 Chevy coupe, they are more than welcome to have the wiper motor).
30aadoodlebug is offline   Reply With Quote
Old 12-26-2015, 09:43 PM   #13
Tom Wesenberg
I like your Model AA doodlebug with the new white plow. I spent the morning plowing snow with my Original Cub Cadet and a newly painted white blade. I knew after I sanded the rust off and used epoxy paint on the blade the snow would roll off the blade much better, but it works so much better than I expected, that now that I don't even mind snowplowing.
Old 12-27-2015, 07:57 AM   #14
BILL WILLIAMSON
Tom,
Spray the blade with "PAM"--I use it under the clean deck of my rotary mower, to keep the grass from sticking. Armor-All works, also.
Those 2 products are great to "mist" your undercarriage & under the fenders, before a LOOOONG tour, for quick/easy clean up, afterwards.
Ray used to spray the front of his old Chebby Truck & the front of his trailer with "PAM", for EASY BUG REMOVAL, after his trip.
Bill W.
Old 12-26-2015, 11:04 PM   #15
30aadoodlebug
Thanks Tom!
The plow is an original 1930 era "road king" rig. It has the shock bars that run under the frame. I have never been able to find any info on the plow, but the brass plate on the plow itself is pristine for its age. Sorry to hear that you had to plow, but at least you had fun in the snow?
Old 12-27-2015, 05:58 AM   #16
30ccpickup
30ccpickup's Avatar
Info on wipers http://www.mafca.com/tqa_wipers.html
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
