Old 11-14-2015, 06:59 PM   #1
spinelll
spinelll's Avatar
Default Is this distributor cap spent?
Thanks
Leo
spinelll is offline   Reply With Quote
Old 11-14-2015, 07:29 PM   #2
700rpm
700rpm's Avatar
Default Re: Is this distributor cap spent?
I'd say so.
Ray Horton, Portland, OR
Old 11-14-2015, 08:21 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I'm frugal, so I'd use my Dremel with a small drill bit, then grind out the remaining carbon and use a worn out carbon brush to make a new carbon for it. As you can see, I work cheap.
Old 11-14-2015, 08:28 PM   #4
Mitch//pa
Old 11-14-2015, 09:42 PM   #5
Clem Clement
Clem Clement's Avatar
the cap should "quack" or it or the rotor is no good.
Clem Clement is offline   Reply With Quote
Old 11-14-2015, 09:54 PM   #6
daveymc29
daveymc29's Avatar
I have had aa couple of the clear caps. They seem to "quack" vewy easily and fall off the distributor body. I have one now that I cannot forse a spark through.
daveymc29 is offline   Reply With Quote
Old 11-14-2015, 10:15 PM   #7
Mitch//pa
i just replaced one the other day with the carbon button worn down. the rotor is fine.
they must use off shore carbon
Old 11-15-2015, 02:38 AM   #8
Tom Wesenberg
I made my own clear cap about 15 years ago and only use it as a demonstration piece or for diagnostic purposes. I used a MoPar alternator round brush for the carbon. I drilled and threaded a piece of .435" brass rod and turned a piece of .350" Lexan for the cap. No one sold clear caps at the time and a few were selling very high on ebay, so I planned to make and sell a few, but by the time I found a sheet of clear Lexan the clear caps became available again. I see Bert's has a good price for them now.
