Old 10-25-2015, 04:51 PM   #1
30-9
Default Compression & engine restorer
Hi folks
I know many on here like mmo.
I been reading a lot of positive results with "Engine Restorer". One guy on you tube did before and after results and one cyl went from 45 to 120.
Any one try this stuff on a flatty?
Thanks - 30-9
1939, 1940
30-9 is offline   Reply With Quote
Old 10-25-2015, 05:56 PM   #2
oldford2
oldford2's Avatar
Default Re: Compression & engine restorer
Oh Boy,
I am not touching this one!!!!!!!!!!!!!!!!
oldford2 is offline   Reply With Quote
Old 10-25-2015, 06:34 PM   #3
JSeery
JSeery's Avatar
These are different types of products I believe, somewhat like comparing apples and oranges.
Old 10-25-2015, 06:40 PM   #4
30-9
Hey JS hope all is well.
I'm one that typically don't use supplements like mmo. I know the two are diffrent. In watching YouTube I was pretty surprised by the results of this engine restorer.
I was wondering if anyone on here has used this stuff and saw an increase in compression.
Thanks - 30-9
1939, 1940
Old 10-25-2015, 07:02 PM   #5
JSeery
JSeery's Avatar
I've used it with good results on more modern engines (70 - 80s engines). In the short term it worked well, my concern would be long term and only time will tell. There is no substitute for a rebuild when required, but it did perk the engines up for a quick fix!
Old 10-25-2015, 07:05 PM   #6
30-9
Thx - you see any issue with putting in a flatty?
Thanks - 30-9
1939, 1940
Old 10-25-2015, 07:38 PM   #7
JSeery
JSeery's Avatar
Doubt it would do any harm.
Old 10-26-2015, 07:47 AM   #8
51 MERC-CT
51 MERC-CT's Avatar
No issue at all. Started using it when my flatty had about 72k on it and added it every 2-3 oil changes to now at 112K miles. (reminds me that I have to pickup a can for this next oil change)
Old 10-26-2015, 08:35 AM   #9
Shoebox
Shoebox's Avatar
So, the product name is Engine Restorer, who makes it and in what form does it come, can, bottle, etc. ??
Shoebox
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 10-26-2015, 09:13 AM   #10
corvette8n
corvette8n's Avatar
Shoebox
http://www.restoreusa.com/
Looks like it come in a can Wallyworld carries it.
Old 10-26-2015, 12:33 PM   #11
flatjack9
flatjack9's Avatar
Same as STP.
Old 10-26-2015, 12:41 PM   #12
1931 flamingo
1931 flamingo's Avatar
IMO it won't hurt any engine. Back in the 60's there was an abundance of these kind of "snake oil" additives around. But again, they just "mask" a bigger problem. JMO
Paul in CT
Old 10-26-2015, 01:13 PM   #13
petehoovie
petehoovie's Avatar
https://www.youtube.com/watch?v=YvyYkW42yOc
This guy is really impressed....
Old 10-26-2015, 01:32 PM   #14
34PKUP
34PKUP's Avatar
Originally Posted by flatjack9 View Post
Same as STP.
Guess again.
34PKUP is offline   Reply With Quote
Old 10-26-2015, 04:25 PM   #15
Russ/40
Russ/40's Avatar
Nothing like STP, which is just a viscosity enhancer that reduces oil burning. The Restore product really does work. Just like 51 Merc says it makes a significant difference in not only oil consumption, but compression as well. The product itself is not very viscous. My wife's jeep had an old 327 Chev in it that was a real hog. The restore brought compression up, and it ran well for over a thousand miles. You do have to repeat treatment, but it works. Why I don't know, but my results were great enough to risk you guys calling me a kook
Russ/40 is offline   Reply With Quote
Old 10-26-2015, 04:41 PM   #16
Bored&Stroked
Bored&Stroked's Avatar
Russ . . . yah damn crook! LOL
Old 10-26-2015, 04:44 PM   #17
Vic Piano
Vic Piano's Avatar
I've used Engine Restorer in the V-12 in my '39 LZ (it was rebuilt in 1952). It did cut down on oil consumption (not including leaking, which I have resolved for the most part ) and did restore some noticeable power, especially in 2nd gear... I've got to change the oil in the LZ this weekend so, I'll be putting some more of the 'snake oil' in. along with MMO in the top oiler and gas tank...
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
