Old 10-20-2015, 12:56 AM   #1
V848 Ford
Default checking a coil for a Model A?
Can anybody tell me if you can check a coil with a volt ohme meter to see if it is any good ?
V848 Ford is offline   Reply With Quote
Old 10-20-2015, 02:56 AM   #2
Charlville
Charlville's Avatar
Default Re: checking a coil for a Model A?
This may help?
http://www.aa1car.com/library/ignition_coils.htm
Kevin Flood
West Berkshire UK
Member MAFCGB, VHRA, SAH, Brooklands Trust
Sporadic progress on My 1929 Sport Coupe can be found here along with my blog
http://automotiveamerican.com/
Charlville is offline   Reply With Quote
Old 10-20-2015, 03:21 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
1.2 ohms on the primary and 3,200 to 4,400 on the secondary. Primary should draw 4 1/2 amps if you have a power supply.
Old 10-20-2015, 07:33 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Ohm readings is a good preliminary check, but you need to run the coil to be sure the spark doesn't short to the case or jump across the tower to a terminal. Also be sure to run it long enough to get it to normal operating temperature. The same goes for the condenser.
