Old 09-30-2015, 02:15 PM   #1
dirt t
Default A Frame dimensions
Could use some help. wescottsauto.com lists 103.5" wheel base, but if you add all there dimensions it comes up a 1/4" short. the running board mounts from center of rear cross member to center of drivers rear running board bracket is 22 1/2 " 29 Ford chassis lists it at 29" and 27 3/4" to front drivers bracket. Wescott has no dimension for front bracket. I have spent hours looking for the correct dimensions to still have doubt what is right. I purchased Model A plans from an outfit in Canada and they are hot rod plans without any original dimensions for me it was a waste of money.
Thank you for you time. If mounting hole dimensions are correct please let me know.
Terry
dirt t is offline   Reply With Quote
Old 09-30-2015, 03:37 PM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: A Frame dimensions
I believe the frame dimensions are also in the Judge Standards.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 09-30-2015, 04:48 PM   #3
160B
160B's Avatar
I looked in the RG&JS and there are no frame dimensions.
Here is a link to a site with the frame dimensions
http://1929fordhotrod.com/johnsblog/...me-dimensions/
Attached is the photo from the above link.
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 09-30-2015, 04:51 PM   #4
Charlie Stephens
The dimensions are also at: wescottsauto.com
Charlie Stephens
Old 09-30-2015, 05:05 PM   #5
160B
160B's Avatar
Here is a link to Westcott site with the frame dimensions.
http://www.wescottsauto.com/WebCatal...ram1928-31.pdf
Attached is the jpg from the above link.
Old 09-30-2015, 06:13 PM   #6
dirt t
Gentlemen your not getting my point Wescotts wheel base numbers when added are 1/4" short. The 29 model a drawings show much different dimensions for running board bracket mounts thank you for your reply's I'm trying to get accurate numbers .
Old 09-30-2015, 08:51 PM   #7
MikeK
MikeK's Avatar
Found this floating around. Don't know the source. See if it adds up. Good luck.
MikeK is offline   Reply With Quote
Old 10-01-2015, 10:41 AM   #8
katy
katy's Avatar
Wescott's drawing shows from centre of front cross member to centre of rear cross member as being the same as the wheel base. This is wrong because of the camber of the front axle. The wheelbase is actually longer than the crossmembers C to C.
Ken in Alberta
Old 10-01-2015, 01:09 PM   #9
dirt t
Katy, add all the numbers from front center line to rear center line there's 1/4" short. Which of the measurements is off?
Old 10-01-2015, 03:09 PM   #10
Karl Wescott
Karl Wescott's Avatar
Here is the chassis diagram from "How to Restore the Model A Ford" from Clymer Publications. This might clarify, or throw fuel on the fire.
I will attempt to re-check all measurements against original frames this winter and revise the drawing as needed.
Karl Wescott
Karl Wescott is offline   Reply With Quote
Old 03-28-2020, 10:29 AM   #11
dirt t
also some of the body mount brackets and running board stuff is off.
Old 04-03-2020, 01:26 PM   #12
Tinbasher
Tinbasher's Avatar
Welcome to Aftermarket Parts. Good enough seems to the the norm. Ugh!! 1/4" is the max for spec on a frame. But "0" is better.
Tinbasher is offline   Reply With Quote
Old 08-28-2022, 07:11 PM   #13
alanp561
alanp561's Avatar
Pretty sure I saw a Model A factory drawing with a scale " plus or minus 1 inch"
alanp561 is offline   Reply With Quote
Old 08-29-2022, 06:23 AM   #14
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
FWIW, I own copies of several of the A-5005-* Frame Assembly drawings and the A-5016 Side Member drawings, and I can assure you that you are mistaken.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 06-18-2025, 02:44 PM   #15
Oldbluoval
Oldbluoval's Avatar
Ford would have never accepted +- 1” on anything
Oldbluoval is offline   Reply With Quote
