Old 08-31-2015, 09:27 AM   #1
Ed in Maine
Default The New Waterless Coolants (since 2012)
Has any one got any experience in using the new coolants that do not use water. They are pricey but do have expanded temperature capabilities and no corrosion problems. The coolants have a longer life than anti-freeze and are not bad for the environment. It sounds too good to be true! Ed
Ed in Maine is offline   Reply With Quote
Old 08-31-2015, 09:51 AM   #2
Y-Blockhead
Y-Blockhead's Avatar
Default Re: The New Waterless Coolants (since 2012)
I seem to recall recently there was a thread on 'The Barn" about the use of "the new and improved" coolant where it mentioned all the good stuff plus the engine ran hotter, which is NOT a good thing.
Old 08-31-2015, 10:38 AM   #3
Gary Karr
Gary Karr's Avatar
Here is an article on YouTube with Jay Leno talking about Evans Coolant.
https://www.youtube.com/watch?v=t7PykrgzWPQ
Gary Karr is offline   Reply With Quote
Old 09-01-2015, 07:18 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
No mention was made about freeze protection when using the waterless coolant.
Old 09-01-2015, 10:36 AM   #5
Victoria31
Talking Re: The New Waterless Coolants (since 2012)
While it is not easy to find, if you go to their WEB site, under product description it shows -40 degree protection. All in all based on what I see, looks like a good deal.
Victoria31 is offline   Reply With Quote
Old 09-01-2015, 11:49 AM   #6
Tom Wesenberg
While it sounds good, I'll reserve my judgment until it's proven safe. After all when water or 50% antifreeze boil, they carry off a lot of heat. Since the waterless boils at such a high temperature, it will loose that protection. Just recently someone had an engine damaged by overheating, and as I recall they were using waterless coolant.
Old 09-01-2015, 10:11 PM   #7
AL in NY
AL in NY's Avatar
Evans coolants have an expanded temperature range but they do not have the heat carrying capacity of 50/50 antifreeze or water. Your engine will run hotter and may still boil over. There is no substitute for a clean radiator and engine block to prevent overheating.
AL in NY
AL in NY is offline   Reply With Quote
Old 09-02-2015, 12:32 AM   #8
Henry's Lady's Man
Henry's Lady's Man's Avatar
I know nothing about this coolant, but I DO know that water is the ONLY liquid I know of that EXPANDS when it freezes, or solidifies (some liquids get "plasticy" or gel-like before solidifying). They ALL contract or shrink. ONLY water expands, busting blocks. So, without water, there is no chance of expansion of the coolant.
Again, I don't know what the stuff is made of, but I would suspect freezing is not an issue at all.
... prosperity is not the product of charity but of industry - HENRY FORD
Henry's Lady's Man is offline   Reply With Quote
