Old 08-26-2015, 05:22 PM   #1
kw120
Default 47 Ford saden front end help
Hello. I'm rebuilding the front end of a 47 Ford sedan and having trouble getting it back together. I'm having trouble getting the draglink from the steering box to the pass spindle back in place. The draglink hits the wishbone long before it is in place. What am u doing wrong? I put a lowering spring in it but that is the only mod. Im also having issues with the shock. It has tube shocks on it. But they are hitting the stabilizer ends. I also can't find new shocks. Anyone know where you can get shocks with the pin needed to attach to the eye in the mount?
kw120 is offline   Reply With Quote
Old 08-26-2015, 07:49 PM   #2
f1builder
Default Re: 47 Ford saden front end help
someone on here sells the shock mounts, bolt ins. might have to re-mount the shocks to get them right. can't really tell but you might have the shorter dogbone which would reduce your clearance.
f1builder is offline   Reply With Quote
Old 08-26-2015, 09:22 PM   #3
Old Henry
Old Henry's Avatar
Here is how the tube shock connects to the axle that's made for it.
It doesn't look like your axle has the mount for a tube shock. You may have to get the bolt on kit to use tube shocks. C&G has it here: http://cgfordparts.com/ufolder/cgcat...mber=11A-14308
The drag link is made with a bend to clear the wishbone. Mine still rubs sometimes on sharp right turns.
I wonder if you might have the drag link ends reversed. The adjustment collar on mine is at the end that hooks to the steering arm so that the bent end hooks to the wheel. Or, maybe your drag link is twisted so the bend is not down to clear the wishbone. The bolts on both ends of the drag link are inserted down from the top so that the nut is on the bottom. Is yours like that?
Old 08-27-2015, 08:36 AM   #4
Deuce Man
Deuce Man's Avatar
Hey Henry, is that brake line ok ? Rich
Deuce Man is offline   Reply With Quote
Old 08-27-2015, 09:41 AM   #5
Old Henry
Old Henry's Avatar
Yes. That's just the paper label on it coming off.
