#1 |
I installed a T5 transmission from a 1987 Chevy S10 in my Town Sedan. Overall I'm quite happy with it. However, 1st is very low. In fact I feel all the gears might benefit from a better rear end gear ratio but I'm not sure what gears would be best. I currently have a the stock 3.78 gears. I would appreciate any thoughts on this matter.
#2 |
A lot is going to depend on what you have for a motor. For a stock rearend you have a 3.54, a 3.27 and a 4.11 available, other than your 3.78.
In theory you can divide the ratios and find the reduction in RPM you will get for a given speed, but you eventually get to the point where the motor cant pull the taller gear. Good Luck |
#3 |
I believe there are many diff tranny ratio's available also. You might try asking this on the HAMB or the EV8 forum. It may not be your rear end ratio.
Paul in CT |
#4 |
#5 |
Thanks to everyone for the feedback. I have a rebuilt, stock engine. I currently have a 3.78 rear. I have identified my transmission gear ratios from the chart:
3.39 3.50 2.14 1.39 1.00 0.78. The car runs fine, have had it up to 60 mph, no problem, but 1st is very low, 4th seems to be needed a bit early. With all this info., how do I proceed. Perhaps a 3.54 rear end ratio would be helpful? Or maybe just leave it alone? |
#6 |
#7 |
Why did you change it in the first place ? Wayne
#8 |
well the t5 in my 4 banger 95 s10 your shifting every 10mph increase in speed. thats with the factory s10 ratio of 3.73.
you have a truck transmission which i feel is better in a model A due to its power to weight ratio. I dont think you would be happy if you had a t5 out of a camaro or something sporty.
1929 Model AA - Need long splash aprons! |
#9 |
I have a banger with a t-5 . tried 3.54 but still to low . I just installed 3.27 hoping to help 1st gear ................ my t-5 is a 0.78 I believe .
V4f |
#10 | |
![]() Quote:
#11 |
Ron-5th gear is fine 60 -65 mph, and doesn't seem to want anything more.
As you said, maybe I'll just leave it. I'm guilty sometimes of seeking perfection. V4F-please let me know how the 3.27 performs. When I look at the description of the 3.27 gears in the Model A vendor catalogs it always states: "must have a strong engine". What does that mean? Is a rebuilt stock engine, stock head strong enough? katy-2nd is ok on perfectly flat ground, but the slightest incline and it's "boggy". |
#12 |
I'm using the T-5 from a Chevy truck with a B engine equipped with a CRAGAR head, headers, etc. the rear end is 3:54. Add an F-100 steering box and yopu have the perfect touring car
No restorable Model A's were harmed in the building of this truck! |
#13 |
T5 first gear of 2.95 is about ideal, just slightly taller than stock.
A's Always Dave |
#14 | |
![]() Quote:
More of a HAMB question. There's lots there about T5's. |
#15 |
Don't forget: tire size also makes a big difference!
#16 |
#17 | |
![]() Quote:
OR....... You can swap the NWC Camaro main shaft with the S-10 main shaft, assemble the trans normally using the Camaro gear set, and the speedo will work as is. The Camaro gears are completely interchangeable with the S-10 main shaft. Now, you have a great gear ratio (2.95 1st gear), including a close-ratio gear set that shifts wonderfully, and a .63 OD ratio. The ONLY reason you ever need anything "S-10" is for the tail shaft housing and shift lid which moves the shifter farther forward. The S-10 gear sets SUCK hugely! But, then again, this is a five year old thread! DD |
#18 |
When looking for a 5 speed trans. I wanted an s-10 because of the shifter location. A trans out of a 4-cyl has a low 1st gear and a not too tall 5th gear which is what I wanted. Could not find one in So Cal that was not over $800 (Hot Roders love these transmissions) Did find a very good trans out of a V6. Changed the diff. to 4.10. The low 1st is for parade use and a close to stock engine can pull 5th gear. Very happy with that combination.
#19 | |
![]() Quote:
#20 |
My Vicky has an S-10 trans. w/the 4:1 1st gear and 26% OD and a 4.10 rear end. I normally start in 2nd gear and with the 26% OD, it is great on the highway. I do use first when starting on a hill, and when hill-climbing.
