Old 07-30-2015, 05:14 PM   #1
david.skinner
david.skinner's Avatar
Default 38 coil position
Just a quicky: Got my refurbished distributor and rewound 12V '38 coil from Skip yesterday. Put the distributor in and wammo - new engine compared to the old one. Understatement to say that I am pleased.
Today's job is to remove the modern coil and fit the rewound original on the inlet header mounting plate that I have found. however - which way does the coil mount? HT lead up or down?
Many thanks.
D.
david.skinner is offline   Reply With Quote
Old 07-30-2015, 05:19 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: 38 coil position
stock 38 Coil fits on top of distributor ,sounds like you have the 47/48 one that mounts HT lead down Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 07-30-2015, 05:24 PM   #3
david.skinner
Oh yes - sorry engine is 38 but distributor is crab so 42ish? - many thanks Ted
Old 07-31-2015, 01:34 AM   #4
david.skinner
Just been out for a test drive and its a whole new engine - no hesitation, heaps of torque, smooth power from its low idle, runs cooler, and overall a whole lot nicer to drive. Many thanks to the forum and to Skip.
D.
