Old 07-22-2015, 01:04 PM   #1
lnvmyrick
lnvmyrick's Avatar
Default 1931 RPU frame number
Where and how do I find and locate the frame number for CHP in California?
lnvmyrick is offline   Reply With Quote
Old 07-22-2015, 01:19 PM   #2
COOTER
Default Re: 1931 RPU frame number
Top side, driver's side frame rail, under the cowl.
COOTER is offline   Reply With Quote
Old 07-22-2015, 01:58 PM   #3
C26Pinelake
That is exactly where mine is. Wayne
C26Pinelake is offline   Reply With Quote
Old 07-22-2015, 02:06 PM   #4
Charlie Stephens
You should have added that "under the cowl" means lifting the body. If the engine number matches the registration they may let you use that for proof of ownership and then attached a tag to the door jam. Search the archives and you will find a picture showing the exact location (or reference to a site with pictures). FYI, I have a '31 RPU also.
Charlie Stephens
Old 07-22-2015, 02:34 PM   #5
Idaho Brett
Idaho Brett's Avatar
I found a picture that might help.
Idaho Brett is offline   Reply With Quote
Old 07-22-2015, 04:54 PM   #6
lnvmyrick
lnvmyrick's Avatar
How much work is lifting the body enough to see the number?
Old 07-22-2015, 06:33 PM   #7
Indiana A. Lover
Send a message via Yahoo to Indiana A. Lover
I do not want to be a bearer of bad news, but the numbers are very hard to read most of the time.I have had no luck reading numbers with just lifting the body. Be prepared to lift body clear of frame and clean and document with rubbing paper and lead pencil. also take photo and have it notery public stamp it. Well good luck you only have to do it one time Don in Indiana
Indiana A. Lover is offline   Reply With Quote
Old 07-22-2015, 11:59 PM   #8
Charlie Stephens
Also look into acid etching to raise the numbers. This is the method police use when the numbers have been ground off of firearms. I assume the number on your engine doesn't match the paperwork.
Charlie Stephens
