Old 07-13-2015, 12:01 PM   #1
dgkipp
Default Chevy water pump on flat tie
Hi guys , am in the process of putting a blower on my flat head. I have been told that a 348 chevy pump can be used with an adaptor. anyone have any experience. I can't use the original pumps because of clearance problem. Thank you.
dgkipp is offline   Reply With Quote
Old 07-13-2015, 12:15 PM   #2
sidevalve8ba
sidevalve8ba's Avatar
Default Re: Chevy water pump on flat tie
I think Krylon 32 here on the Ford Barn can help you with that.
sidevalve8ba is offline   Reply With Quote
Old 07-13-2015, 12:24 PM   #3
bbrust
bbrust's Avatar
Found this on the HAMB. It's a little old but maybe will help. Bob
http://www.jalopyjournal.com/forum/t...athead.340970/
bbrust is offline   Reply With Quote
Old 07-13-2015, 03:33 PM   #4
Tony, NY
http://cornhuskerrodandcustom.net/Pages/Parts.aspx#
Tony, NY is offline   Reply With Quote
Old 07-13-2015, 10:10 PM   #5
Ol' Ron
Ol' Ron's Avatar
Bak in the 60's we welded a spacer to a 1/4 piece of aluminum to bolt one of those 348/409 water pumps on the stock car hoping iy would cool better. Unfortunately it didn't work, still ran hot. But the adapters were easy to make and I;ve seen several on some street engines. Aftermarket ones are VERY expensive.
Old 07-14-2015, 08:05 AM   #6
G.M.
This is very expensive and it would be interesting to know how many gallons this pump produces in a 5 minute time period. Stock and after market 37 to 53 pumps deliver about 65 gallons each in 5 minutes and can vary a little but not much. Skips pumps with the body modifications and his turbine impeller delivers 110 gallons each in 5 minutes. Every pump is set up with exactly the same clearances and everyone is tested and delivers 110 gallons. The out put is variable depending on the ENGINE RPM's and the tests are run at 2,500 RPM's. The 3,400 RPM electric motor on his test machine went bad and was replaced by a 1,700 RPM motor and the output of the pumps dropped from 110 to 55 GPM. This also explains part of the reason these engines run hotter at idle and lower speeds. I seriously doubt the Chevy pump delivers anywhere near the 220 gallons that of the two Ford modified pumps deliver. G.M.
www.fordcollector.com
Old 07-14-2015, 08:16 AM   #7
itslow
itslow's Avatar
What exactly is having the clearance issues? Belt drive to radiator?
Being also a 348/409 guy, I don't think you'll wind up saving much space (if any) by switching from the stock flathead ones if your clearance issue is between the pump and the radiator.
Originally Posted by G.M. View Post
...I seriously doubt the Chevy pump delivers anywhere near the 220 gallons that of the two Ford modified pumps deliver. G.M.
A stock '58 pump supposedly puts out a flow rate in the low 50's GPM at 4000 rpm using the stock pulley.
An individual Ford pump may be able to pump 110 GPM on a stand, but I really doubt it'll pump that much once you put a restrictive old Ford radiator in front of it.
EDIT: Just realized that you stated 110 gallons in 5 minutes for the Ford pump, for a total of 44 GPM. The GM pump would be at >250 gallons over 5 minutes.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
