Old 06-24-2015, 08:17 PM   #1
daveymc29
daveymc29's Avatar
Default An old truth driven home
Couple of weeks back I was adjusting my clutch and decided to remove the pedals from their shaft and put some grease on it, not that they were sticking, but they had never been greased since I acquired the car in 1993. 1929 without zerks to grease it, but easy enough to do. Just a dab here and there, put her back together and drove it most every day. It slowly developed a rattle that on a couple of hundred mile outing a few days back developed into a real concern. I pulled up the floorboard and examined things, Wow is the brake pedal loose and the clutch isn't a lot better. I remember my dad telling me once not to grease the front end of my well worn 40 Ford or it would wander all over the road until I rebuilt it. Should have asked him about greasing the foot pedal shaft also. But then he's been gone for quite a spell now, so I probably would have forgotten his answer until it was too late. So tomorrow out with the tranny and in with a new shaft and some bushings.Well, when I get back from Mitchell's. Gonna be zero here tomorrow, but with a ten in front of it or maybe an eleven/
daveymc29 is offline   Reply With Quote
Old 06-25-2015, 12:09 PM   #2
burner31
burner31's Avatar
Default Re: An old truth driven home
I've always found grease to be a good thing.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 06-25-2015, 01:15 PM   #3
Boston Bruce
Boston Bruce's Avatar
Good luck getting the old shaft out. I had one on my '31 sedan that just would not budge no matter what. Even used an air hammer on it. Ended up replacing the bell housing anyway because the original one had been "customized" by a previous owner - a couple of extra holes.
Boston Bruce is offline   Reply With Quote
Old 06-25-2015, 03:05 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
"MAYBE" the noise would have developed, even if you hadn't greased it?? Model A noises/quirks are just a part of the "MODEL A EXPERIENCE"-------It AIN'T a DUESENBERG!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-25-2015, 04:00 PM   #5
Cape Codder
Cape Codder's Avatar
I thought it was possible, although not easy, to remove that shaft without removing the transmission/bell housing ?
Cape Codder is offline   Reply With Quote
Old 06-25-2015, 07:26 PM   #6
Brentwood Bob
Dave, you are on a roll.
Bob
Brentwood Bob is offline   Reply With Quote
