Old 06-24-2015, 06:25 PM   #1
anteek
Default '34 pickup blocks under cab
assembling a '34 cab from pieces. How should it be blocked/positioned to get the doors aligned right. No frame right now to use.
anteek is offline   Reply With Quote
Old 06-24-2015, 10:29 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: '34 pickup blocks under cab
A line the top of the doors first ,you may need to rack the opening ,then aline the hinge side next ,then the shut side .weld or bolt a x frame on the inside of door openings .Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 06-25-2015, 12:22 PM   #3
2ndgeer
2ndgeer's Avatar
I took this picture off the web a while back. You can see the wooden blocks that rest on antisqueak pads (not shown in this picture) on the frame. The antisqueak pads are typically 1/8 to 1/4 inch thick. Hope this helps.
2ndgeer is offline   Reply With Quote
Old 06-25-2015, 03:30 PM   #4
Newc
Newc's Avatar
Hi all; Some wood kits copied old shrunken original wood blocks. Be prepared to add spacer pads if necessary to keep cab above the frame. Without a frame it is tricky to get a good door fit. Newc
Newc is online now   Reply With Quote
