Old 05-24-2015, 03:22 PM   #1
Divco one
Divco one's Avatar
Default 6 blade plastic fan
Would the 6 blade plastic fan be more balanced than the 2 blade aluminum stock fan? Is the only benefit more cooling?
Divco one is offline   Reply With Quote
Old 05-24-2015, 03:36 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: 6 blade plastic fan
The majority of our guys run them, NEVER saw one break!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 05-24-2015, 05:16 PM   #3
CarlG
CarlG's Avatar
The plastic fan also weighs a lot less than does the aluminum fan.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-24-2015, 05:20 PM   #4
john in illinois
john in illinois's Avatar
I have had good luck with mine.
John
john in illinois is offline   Reply With Quote
Old 05-24-2015, 05:34 PM   #5
C26Pinelake
They do a great job but they look so Mickey Mouse ! Does not seem to go along with the rest of Henry's creation ! Wayne
C26Pinelake is offline   Reply With Quote
Old 05-24-2015, 07:53 PM   #6
walt jones
walt jones's Avatar
C26Pinelake X 2.
Walt
walt jones is offline   Reply With Quote
Old 05-24-2015, 08:52 PM   #7
BILL WILLIAMSON
Use PLASTIC fans for safety, did you ever try to put your elbow against the back side of a METAL fan? PLASTIC fan jist goes, "BRRRRP!! YES, I'VE DONE IT!!
Bill W.
Old 05-24-2015, 10:44 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Originally Posted by divco one View Post
would the 6 blade plastic fan be more balanced than the 2 blade aluminum stock fan? not necessarily is the only benefit more cooling? the model a times did a test of the various fan blades on the model a, measuring the air flow at given engine rpm and several locations, in front behind and by the middle engine area. The 6 bladed fan did not win.
Old 05-24-2015, 10:53 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Bill W.
Didn't your mother tell you not to put things in the fan.
And that includes elbows and pencils.
Old 05-24-2015, 10:56 PM   #10
Mike V. Florida
Joop posted this back 4 years ago;
Found this on the internet.
Air through the radiator is the important consideration. That is where the heat transfer occurs. Meauring the air flow into the radiator that results from the turning fan is the test to run. That was done and reported in the Spring issue of the Model A Times. Page 7 contains a chart tht shows the results of three fans, the 2 blade, the 4 blade, and the 6 blade.
In front of the radiator the air speed (mph) created by the fan was measured as:
blades-----2---------4--------6
500rpm---4.8--------4.5-----3.0 mph
1000rpm--9.0--------9.6-----8.5 mph
1500rpm--14--------14------13.5 mph
Old 05-24-2015, 11:09 PM   #11
CarlG
CarlG's Avatar
After my 4-blade "truck" fan took out my radiator when the rivets let loose, I opted for the plastic fan. Even if it does come loose (witch I doubt it will) the damage it would do to the radiator and/or other sheet metal couldn't help but be considerably less. I also realize that air flow on all 3 fans is essentially the same, so that is not a consideration. Anything past 25 mph, a fan is not needed anyway.
Alaskan A's
Old 05-25-2015, 11:40 AM   #12
BILL WILLIAMSON
What would our world be like without PLASTIC?
Bill W.
Old 05-25-2015, 12:10 PM   #13
Tom Wesenberg
Bill W.
A lot less road litter.
Old 05-25-2015, 12:27 PM   #14
Not George
Not George's Avatar
Bill W.
We wouldn't have these computers to ponder such questions on forums like this.
Not George is offline   Reply With Quote
Old 05-25-2015, 03:13 PM   #15
BILL WILLIAMSON
Tom,
If you cleaning the roadside, DON'T touch them corked up gallon jugs of some UNKNOWN YELLOW LIQUID, them dudes will BLOW UP, from sittin' in the HOT SUN!!!!!! The fumes would probably power a Model A!
Bill W.
Old 05-25-2015, 03:17 PM   #16
Mitch//pa
Tom,
Bill W.
u mean these bottles
