Old 05-21-2015, 12:15 PM   #1
f1builder
Default floor shift conversion on 47 tudor
i have a 47 tudor column shift and i just picked up a hurst 3sp syncroloc shifter which i want to put on. the tranny mount is smack dab in the way. does anyone have any advice on how to do this install? right now i just can't picture how to get it done. thanks for any help.
f1builder is offline   Reply With Quote
Old 05-21-2015, 12:42 PM   #2
bobH
Default Re: floor shift conversion on 47 tudor
Ferggidit
If u want a floorshift, get a case & do it right
bobH is offline   Reply With Quote
Old 05-21-2015, 12:47 PM   #3
JSeery
JSeery's Avatar
This sure seems like doing it the hard way! Why not swap out for a flow sift transmission?
Old 05-21-2015, 01:40 PM   #4
f1builder
i have several trannies, a 39 case and a 41 gearset i could use, just didn't want to do the swap on that yet. i also have a 3sp toploader out of a 53 f150 which should work out. thanks for the advice.
Old 05-21-2015, 04:24 PM   #5
oldskool
oldskool's Avatar
does your mounting bracket look like this ?this is correct mount
oldskool is offline   Reply With Quote
Old 05-21-2015, 04:38 PM   #6
f1builder
yes oldskool, it looks like the shifter but the bracket is handmade as is. is the picture you show for the 47 ford? if so i could modify mine if i had your bracket design and mounting instructions.
Old 05-21-2015, 11:09 PM   #7
fordor41
fordor41's Avatar
I believe some of the '70's Mopars had the shifter mounted to the floor, not the tranny
fordor41 is offline   Reply With Quote
Old 05-22-2015, 12:20 AM   #8
bobH
With this thought in mind, I have one car that has a similar shifter. I made a sturdy bracket to mount it on the floor, big enough to spread the load out. Then I made trans shift arms, with length to suit, for correct travel. In the case of a 47, I believe this means a fabbed (or modified) arm that is 'upward', instead of downward, (as the stock 47 arms are). And, of course, new connecting rods.
I'd provide a sketch, if I had a way to post a pict.
I've had this car and shifting arrangement for over 10 years - no problems. I'm sure you could work it out.
just one more opinion...
Old 05-22-2015, 08:02 AM   #9
Henry/Kokomo
Henry/Kokomo's Avatar
Hurst made a kit to mount one of their shifters to 46-48 Fords. Required cutting the floor but bolted on to existing bosses on the transmission/u-joint housing utilizing longer bolts.
Henry
Henry/Kokomo is offline   Reply With Quote
Old 05-22-2015, 10:08 AM   #10
oldskool
oldskool's Avatar
here is the hurst shifter installed in my 46 mercury , shifting was precise and and positive,i had bad syncros in trans and went with a 39 top loader,the shifter was nos
Old 05-22-2015, 10:31 AM   #11
f1builder
oldskool....that is what i needed. i remember having a hurst shifter on my 41 but it was like that when i got it and i couldn't figure out how to mount on my 47. thanks loads and thanks to all for help. i am going to use my hurst cause i like it. i do have a 78 box with a bad cluster and a nice 41 gear set i could use but will save those for another project. my 47 is not a restore it is a old school 50's style hotrod.
Old 05-27-2015, 08:53 PM   #12
f1builder
oldskool.....do you happen to have a few more pics showing both sides of the mount setup for the hurst shifter. my email ([email protected]) if you do i would really appreciate it. thanks, george.
