Old 05-19-2015, 10:29 AM   #1
Bolts
Bolts's Avatar
Default 48 coupe- fuel tank filler pipe hose installation question
What is the best way to install the fuel pipe coupling hose?
The fit of the new hose is tight and I assume hot air to heat it might help getting it on, but what is the best sequence to use?
The new tank is in the car but I can remove it.
Should I grease the inside of the hose?
Does the hose go on the tank first or should I assemble it to the filler pipe first and then make it up to the tank?
Thanks
Nothing wrong with it except for the name on the front.
Alex
Bolts is offline   Reply With Quote
