Old 04-14-2015, 12:02 PM   #1
Terry/Iowa
Terry/Iowa's Avatar
Default Electrical/Ground - Solved
First of all, thanks for all the help and suggestions. The problem turned out to be in the cut off switch I have on the cable to the starter. Originally when I cleaned the ends I didn't think to disassemble the switch to clean the inside and the screw that cuts off the voltage. I did that finally and it seems to have solved the problem. It's nice to have something that simple go wrong once in a while so I can feel like an idiot. Anyway, thanks for the advice.
Terry/Iowa is offline   Reply With Quote
Old 04-14-2015, 12:05 PM   #2
Mitch//pa
Default Re: Electrical/Ground - Solved
glad you found the trouble. its very easy with a testlight or meter
it may also be a good idea to close out your original thread with the fix
Old 04-14-2015, 12:32 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I don't recall the cutout switch being mentioned in the original thread, and that's why it's important to mention any modifications to the car. A guy in our club had starter preoblems and had me go through the starter. I found a problem with someone undercutting the commutator and a piece of copper shorting two bars, but the real problem turned out to be a bad cutout switch.
Glad it was an easy cheap fix for you.
Old 04-14-2015, 12:39 PM   #4
gweilbaker
gweilbaker's Avatar
Terry, Good to hear you solved the problem, but a word of caution, if your switch is the "quick and dirty" variety it will fail quickly and could over heat due to the internal resistance. A good one should be in the neighborhood of 40 ~50 dollars depending in style.
gweilbaker is offline   Reply With Quote
Old 04-14-2015, 12:39 PM   #5
Mitch//pa
yep agree
its all a guessing game most of the time with never enough info
Old 04-14-2015, 08:27 PM   #6
jax55
jax55's Avatar
Glad you got it figured out and thanks for letting us know the cause/ fix.
jax55 is offline   Reply With Quote
