Old 04-13-2015, 07:51 PM   #1
anteek
Default '28 AA question
In '28 what cowl did an AA have,if no cab? I have a roadster cowl I'd like to use with a wooden C cab. thoughts,ideas???????????
anteek is offline   Reply With Quote
Old 04-13-2015, 09:08 PM   #2
Steve Plucker
Default Re: '28 AA question
All 1928 cowl sections were the same for the most part with the exception of the early Fordor Sedan which had an air vent on the cowl itself.
Go for it.
Pluck
Old 04-14-2015, 08:20 AM   #3
Neil Wilson
Neil Wilson's Avatar
Steve is correct, except for the Fordor Sedan, all A and AA bodies used the same cowl for 1928 and 1929. This also applies to an A or AA chassis only setups. I don't know about the 1930/1931 cowl.
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
Old 04-14-2015, 11:10 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
What do you call the trim line that curves down the side of the 28 and 29 cowls?
That part is different between open and closed cars.
Old 04-14-2015, 02:51 PM   #5
Neil Wilson
Tom,
I am guessing that you are referring to the door hinge pillars? I think Ford's name is "coupe pillar".
An A or AA which was sold as a chassis included the gas tank, cowl, hood, radiator, front fenders.
Old 04-14-2015, 03:12 PM   #6
Tom Wesenberg
Originally Posted by Neil Wilson View Post
Tom,
I take it that part wasn't part of the packege in question then, correct?
I never paid much attention to the basic truck chassis purchase, but thought it would have included the windshield posts.
Old 04-14-2015, 08:48 PM   #7
Neil Wilson
An A or AA chassis included the same parts for 1927 thru 1929. And most likely this is true of 1930 thru 1931.
Attached is the typical AA chassis as it rolled off the assembly line.
