Old 04-06-2015, 08:20 AM   #1
Simonpie
Default New to forum, new Model A owner. Tranny Q.
Simon from Oregon here.
I picked up a running but worn all over 31 stripped down to a speedster pickup. It looks better than that sounds. My problem is I still can't wrap my head around the transmission and I don't have enough experience to tell if I'm just a klutz. I can shift back and forth from 2nd to 3rd or, maybe an occasional grind. I can't get 1st except at a dead stop. If I start in first, I can only get 2nd about 5% of the time. It takes a super low RPM shift, with very smooth motion and a lot of hope. I can't get 2nd or 3rd at a stop. It won't ever go from 1st to 3rd. I checked the clutch adjustment, since drag there can cause issues but it is by the book and works fine. Ideas? Both mechanical and technique wise are welcome.
A search of this site brought up a lot of popping out of gear problems, but I've never had that happen.
Thanks.
Simonpie is offline   Reply With Quote
Old 04-06-2015, 08:23 AM   #2
Jon
Jon's Avatar
Default Re: New to forum, new Model A owner. Tranny Q.
Do you know how to double clutch?
John - Kalamazoo, MI
Jon is offline   Reply With Quote
Old 04-06-2015, 08:23 AM   #3
Jwilli
Jwilli's Avatar
Are you double clutching as you shift?
Jwilli is offline   Reply With Quote
Old 04-06-2015, 08:29 AM   #4
Mitch//pa
make sure your idle speed is set low...
shift from 1-2 about 6mph and 2-3 approx 12 mph
Old 04-06-2015, 08:57 AM   #5
Simonpie
If you mean letting the clutch out as I pass through neutral, then back in as I go into the next gear, yes, that helps in 2-3 and 3-2. It seems to have no effect going from 1-2.
I hadn't thought about idle speed. I'll have to fiddle with that.
From the first few responses, it sounds like me more than machine.
Old 04-06-2015, 08:57 AM   #6
Big hammer
600w gear oil in transmission
Big hammer is online now   Reply With Quote
Old 04-06-2015, 09:09 AM   #7
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Sounds kinda' "normal"---You'll get the "HANG" OF IT!!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-06-2015, 09:17 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
Shift as Mitch said and make sure the engine isn't idling faster than 500 RPM, and have 600W gear oil in the tranny as Big hammer said.
Once those are correct, then when you get to about 6 MPH, push in the clutch and shift to neutral. Let the clutch out and let the engine slow down for a few seconds, then push the clutch back in and shift to second. Once I reach about 15 MPH, I push the clutch in and shift to neutral. Then let the clutch out and let the engine slow for a few seconds, then push the clutch in and shift to third.
When you downshift you push the clutch in and shift to neutral from high at about 15 MPH. Then let the clutch out and rev the engine (usually more rev than you'd think), then push the clutch in and shift to second. I almost never downshift to first, but if I do I make sure I'm going no faster than about 5 MPH.
Synchromesh.........what a great invention.
Old 04-06-2015, 09:37 AM   #9
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
This video should help you. jack
https://www.youtube.com/watch?v=qhL5Pv9dcnc
Jacksonlll is offline   Reply With Quote
Old 04-06-2015, 01:57 PM   #10
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Welcome to the Forum.
Old 04-06-2015, 04:11 PM   #11
Goldhardt
Goldhardt's Avatar
Welcome to the Barn! There is a wealth of information flowing around in here. Use it and enjoy it. Lets see some pictures of your ride!!
Goldhardt is offline   Reply With Quote
Old 04-06-2015, 08:15 PM   #12
Simonpie
Looks like all I need is to be sure I have 600W in the tranny (I think I do, but fresh oil is on the way), lower the idle a bit, and fix the loose nut behind the wheel. It looks like rain for a week, so it might take a bit.
Thanks.
Old 04-06-2015, 08:17 PM   #13
Mitch//pa
wow nice rig
Old 04-06-2015, 09:54 PM   #14
RonC
RonC's Avatar
http://youtu.be/oMeHUTw9jkk
RonC is offline   Reply With Quote
Old 04-07-2015, 10:28 AM   #15
Goldhardt
Goldhardt's Avatar
Nice ride! It looks like it would be a hoot to drive around town! Get her out there and enjoy it!
Old 04-07-2015, 11:09 AM   #16
Rojo
Welcome! Lots of help here....I was going to suggest that you watch Jack Bahm's YouTube video on this very subject but see he already beat me to the posting. Again, enjoy your car and have fun.
Rojo is offline   Reply With Quote
