Old 03-12-2015, 07:28 PM   #1
Nick in Fayetteville
Default Autolite 3077
I've been running these plugs in my A Models for years. Finally used up my supply. Went to buy new ones...and quess what? They don' t make them anymore... Find something you like and it works for you and the manufactures quit making them. What plugs are you guys and gals using? I want a plug that is a little hot. Thanks....Nick
Nick in Fayetteville is offline   Reply With Quote
Old 03-12-2015, 08:38 PM   #2
Bob C
Default Re: Autolite 3077
They show up on Epay once in a while.
Bob
Old 03-12-2015, 08:53 PM   #3
edmondclinton
Try out a Champion W-20.
edmondclinton is offline   Reply With Quote
Old 03-12-2015, 09:38 PM   #4
modelAtony
modelAtony's Avatar
Autolite 3076 same as champion w14 and motorcraft tt10 . Orig 3X champion same as champion w 18 these are for heat range. Have fun modelAtony tony white Lafayette, LA
modelAtony is offline   Reply With Quote
Old 03-13-2015, 07:52 AM   #5
Patrick L.
Patrick L.'s Avatar
Well thats not a good thing to hear. I've been running 3077s for years. They're nice and warm for an old tired engine. Darn.
Old 03-13-2015, 08:27 AM   #6
ModelAMike1930
ModelAMike1930's Avatar
You can get 3076 off the shelf from O'Reilly auto parts, I just purchased some for my "A". Maybe they can order the 3077 for you.
ModelAMike1930 is offline   Reply With Quote
Old 03-13-2015, 02:37 PM   #7
Patrick L.
Patrick L.'s Avatar
And here I thought Nick said they stopped making them.
Old 03-13-2015, 03:35 PM   #8
The TT10 and 3076 are cooler plugs. I think the TT15 is a little hotter and maybe better for touring.
Old 03-13-2015, 05:03 PM   #9
edmondclinton
TT15 is a lot hotter (the same as Champion W89D which is hotter than a W-20)
Also, unless "touring" by your definition means driving slow all the time there may not be a need for a hotter plug.
Old 03-13-2015, 07:47 PM   #10
"Touring" for me is generally running between 40 and 45 mph. If just two or three of us are running together, we will run 50+ mph. I like the hotter plug. Seems to work well with my motor which is not totally stock.
