Old 03-07-2015, 12:29 PM   #1
sphooch
sphooch's Avatar
Default 31 deluxe roadster vacuum line route
Hi guys , does any one know exactly how to route the vacuum line from the wiper motor to the engine manifold??I purchased some of the parts from Brattons and expect them shortly. I'd like to know were does the line come through the fire wall, and what kind of clips hold it in place. I did a search on this site but still have the questions. thanks for the help THE HOOCH
sphooch is offline   Reply With Quote
Old 03-07-2015, 07:40 PM   #2
stewwolfe
stewwolfe's Avatar
Default Re: 31 deluxe roadster vacuum line route
image.jpgHere's a picture of the vacuum line routing through the firewall on my '31 Roadster. Once it's through the firewall it becomes rubber and is routed behind the tank to the driver's side where it goes up the stantion.
'31 40B
'31 68C
stewwolfe is offline   Reply With Quote
Old 03-08-2015, 08:35 AM   #3
sphooch
sphooch's Avatar
thanks for the picture, but can I ask you how the rubber hose under the gas tank is secured to the fire wall? and how high is the line ,is it close to the tank?. really appreciate the help. THE HOOCH
Old 03-08-2015, 10:10 AM   #4
jw hash
jw hash's Avatar
originally it is not a rubber hose under the gas tank. it is a steel line it goes from the back of the fitting in the fire wall a crossed the inside of the fire wall with a slow bend in the left corner and back to under the left stanchion. than it go to a rubber hose. I went to NAPA and bought a 62" small brake line the same size as the vacuum line to make it out of. I still have the original one as a sample.
jw hash is offline   Reply With Quote
Old 03-08-2015, 10:37 AM   #5
HoarseWhisperer
HoarseWhisperer's Avatar
It is mostly metal under the tank, NOT rubber. If you need, I can take photos to post of an original.
I know a lot of things; I just can't remember them all.
1928 CCPU 82-A
1931 Roadster 40-B Dlx (Canadian)
HoarseWhisperer is offline   Reply With Quote
Old 03-08-2015, 11:29 AM   #6
Marco Tahtaras
Marco Tahtaras's Avatar
I couldn't find a pic of the right end but this gives you an idea. The one original indented firewall Roadster I've seen was slightly different in that the line going across the firewall was bent downward near the center and passed through bracket mounted on one of the upper terminal box screws.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 03-08-2015, 02:38 PM   #7
stewwolfe
stewwolfe's Avatar
I crawled in and looked again and my line in the cabin is definitely rubber. I guess I've found yet another incorrect fix the guy who restored mine did.
'31 40B
'31 68C
Old 03-08-2015, 04:15 PM   #8
sphooch
sphooch's Avatar
Yes Please ,if you can take the pictures that would be GREAT, the fitting through the fire wall to the stanchion with any brackets or clips would be extremely help full. I thank you so much for your efforts . THE HOOCH
Old 03-09-2015, 10:59 AM   #9
HoarseWhisperer
Hey Hooch;
In addition to Marco's fine photos, here are some quick snapshots of the vacuum line routing on my 31' Roadster. Click on the thumbnails to enlarge. Hope it helps.
1928 CCPU 82-A
Old 03-18-2015, 06:32 PM   #10
swo4rd
swo4rd's Avatar
It is the same for a Deluxe Phaeton...thanks for posting these informative photos Marco and Horsew...
Swoff
swo4rd is offline   Reply With Quote
Old 06-10-2025, 11:14 AM   #11
JRShaw
JRShaw's Avatar
Smile Re: 31 deluxe roadster vacuum line route
Steve - Were there any special fittings, etc. involved at the firewall connection on the passenger side? The reason that I am asking is that with my roadster about 90% done, it is impossible for me to get at the gas tank bolts, etc.
Thank You in Advance
Joel R. Shaw
JRShaw is offline   Reply With Quote
