Old 02-23-2015, 10:17 AM   #1
johnbuckley
johnbuckley's Avatar
Default Starter ring gear for multiplate clutch flywheel?
Does the starer ring gear A-6384 fit the multiplate clutch flywheel? Also what is the part number for the bearing on the multiplate clutch (we call it the spigot bearing over here) that sits in the center of the flywheel and carries the main drive gear thru' the clutch? Thank you.
johnbuckley is offline   Reply With Quote
