Old 01-17-2015, 08:59 PM   #1
Craig CT
Craig CT's Avatar
Default valve insert and cutter
Hi all; Can anyone tell me the OD of the standard valve seat insert and the recommended cutter size for it. Thanks in advance, Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain.
Craig CT is offline   Reply With Quote
Old 01-18-2015, 01:40 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: valve insert and cutter
original Ford--
40-6057-c 1.6530 --1.6535 od
40-6057-d 1.6330-1.6335 od
I would suggest measuring any seats you get before cutting the hole to fit them into
Old 01-18-2015, 05:57 AM   #3
JWL
For the original seat ring the cutter blade measures a few 10ths over 1.625. However, it cuts a slightly larger diameter counterbore. The larger diameter seat ring was for salvaging blocks which had a loose ring.
JWL is offline   Reply With Quote
Old 01-18-2015, 09:57 AM   #4
rotorwrench
rotorwrench's Avatar
I'd purchase new stellite seats first then measure them to find a cutter that will set you up with an interference fit. Just like cylinder bores, you would never want to fit a close tolerance part without the part you are going to put in there in hand.
