Old 01-07-2015, 10:04 PM   #1
Hardtail75
Default 28 Sport Coupe body dimensions and alignment
Hello gents happy new year. I am getting back to work on my car now. I decided to keep the original subrails and repair them instead of ordering a reproduction set. Just ordered a bunch of parts, door handles both inside and out, rods, latches, front leaf spring with reversed eyes, body mounting blocks and pads, cowel shims, hinge pins etc. I read through vicks website on how he put his body back together. I don't have a jig so I advised it is best to assemble everything on the frame.
Does anyone have dimensions for the sport coupe to line the body and doors up? I have searched the forum and found dimensions for a roadster. I am told that I need to start with the cowel and work my way towards the rear. So once the cowel is bolted, hang my doors and then once they swing smoothly attempt to mount the body with rough tacks so you can easily adjust? Never done this before so I am just trying to absorb as much information on the subject before the parts arrive.
Thanks!
Hardtail75 is offline   Reply With Quote
Old 01-07-2015, 10:29 PM   #2
Tinbasher
Tinbasher's Avatar
Default Re: 28 Sport Coupe body dimensions and alignment
Hi Hardtail. Fit Your Rad and Hood also. Then Start at the cowl to get the hood fit and work your way back.
The Old Tinbasher
Tinbasher is offline   Reply With Quote
Old 01-08-2015, 08:49 AM   #3
Hardtail75
The Old Tinbasher
Cool thanks Tinbasher. My hood is a little bent on the panels but that shouldn't be a big issue. We do this because if you don't the hood can be out of alignment?
Do dimensions for sport coupe body exists fellas? I have searched through historical sites but can't find the body dimensions on the inside for the sub frame.
Thanks.
Old 01-08-2015, 11:40 AM   #4
Flop
Make things fit to your body and your frame . Just my opinion !! These cars have had 80 years of abuse /rot/repair. Fit the hood to the rad and cowl line up the subframe to the frame and start putting the body back together .
Please call or email while website is down!
412 867 1659
[email protected]
https://www.facebook.com/flop.custom
Flop is offline   Reply With Quote
