Old 01-05-2015, 10:15 AM   #1
Bob from Northport
Bob from Northport's Avatar
Default Flywheel question
Is there a way to check a flywheel to see if the surface needs to be machined after it is removed and cleaned??
Thanks!!
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 01-05-2015, 10:36 AM   #2
Gunmetal blue2
Gunmetal blue2's Avatar
Default Re: Flywheel question
You look for grooves in the surface and burn marks. Take a straight edge to the face to see it its flat. I have always had it resurfaced, with it already out of the car or truck.
Gunmetal blue2 is offline   Reply With Quote
Old 01-05-2015, 11:42 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
Important are:
1. Clutch face is parallel to the crankshaft flange;
2. Clutch face is flat, so no clutch chatter;
3. Ring gear is a snug fit.
Consider having the flywheel lightened and machine for a V8 clutch. Doing so will decrease the stress in the rear main bearing, make shifting easier, enable quicker acceleration and facilitate braking.
Bob Bidonde
