Old 01-02-2015, 01:23 PM   #1
FlatheadTed
FlatheadTed's Avatar
Default resitor
I enjoyed the benefit of Henrys 4,1/2 volt Ballast resister this week ,I left the ING on for three hours and the coil only got a little warm ,Started right up , the condenser here is on the Generator .away from the distributor. Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 01-02-2015, 02:55 PM   #2
tubman
tubman's Avatar
Default Re: resitor
Points left in open position? My old Irish boss used to say "It's better to be lucky than smart!".
Old 01-02-2015, 03:16 PM   #3
FlatheadTed
Default Re: resitor
I could be wrong ,But the coil was warm ,What happens under these circumstances the ballast heats up increasing resistance and reducing voltage to the coil and points .Part of Henrys coil protection .Ted
Old 01-03-2015, 12:17 AM   #4
supereal
supereal's Avatar
Default Re: resitor
The condenser on a generator is likely for radio noise suppression, not ignition.
supereal is offline   Reply With Quote
Old 01-03-2015, 02:36 AM   #5
FlatheadTed
Default Re: resitor
yes I understand that's normally the case ,but here we have the wire going to the points side of the coil .Ted
