Old 12-12-2014, 08:15 AM   #1
Blu Dice
Blu Dice's Avatar
Default AMP gauge acting up!!
Drove the '52 in to work today - cold out mid 20s - lights & heat blower on. AMP gauge started showing a discharge while cruising, then jumped back and forth, then started showing a charge as it should. Very weird. So where do I start - battery is fairly new, belt is tight, wiring is ok - not pertect. I've only have had this car a month so many unknowns.
Blu Dice is offline   Reply With Quote
