#1 |
Guys, on your trans rebuild check list remember to inspect more than just the condition of gear teeth. The roller / needle bearing bores in the cluster
and main drive gear....very critical obviously....NOS measures 1.1255.... 1.126 I think anything over 1.129 is problematic. The pilot bearing dia on the main drive gear....I like .686 / .683. Often over looked ,I have discovered, is the thin wall bushing in second gear on the '39 up trans. After rebushing 2nd I fit it to its mainshaft with a light drag then run it in at 2100 rpm in my lathe. It ends up with an almost free spin but no rock at all. Charlie ny |
