Old 11-30-2014, 05:39 PM   #1
Lawrie
Lawrie's Avatar
Default bore gauge
I,m going to buy a bore gauge ,to measure my rods and bores,I borrowed one from a mate and they make measuring so much easier than using telescopic gauges and a mike.
I know that mitutoyo make rurally good quality stuff (expensive),but see that there is a brand called FOWLER on Ebay, they seem a lot cheaper ,
would any one have any knowledge of the fowler ones.
I,m thinking fowler maybe a western brand ,but you know how the Ch------ work.
Thanks Lawrie
Lawrie is offline   Reply With Quote
Old 11-30-2014, 05:49 PM   #2
modela4shane
Default Re: bore gauge
Starrett or Goodson. Very good quality
modela4shane is offline   Reply With Quote
Old 11-30-2014, 07:39 PM   #3
quickchange34
quickchange34's Avatar
I use a Mitutoyo it has given me good service over the years. Fowler is a
cheaper made unit. It may work for you if you don't use it a lot.
quickchange34 is offline   Reply With Quote
Old 11-30-2014, 08:09 PM   #4
Fordestes
I've used quite a bit of fowler stuff with good sucess, although I am retired and don't do any outside work anymore. If I used it often I would invest in a good unit that will outlast the off brand, I am a Jouneyman machiist ,the job is only as good as the quality you put into it.
Fordestes is offline   Reply With Quote
Old 11-30-2014, 08:36 PM   #5
34fivewindow
34fivewindow's Avatar
Bought mine from Goodson. and like it.
34fivewindow is offline   Reply With Quote
Old 11-30-2014, 08:39 PM   #6
al pa.
google Lufkin tools,very good quality.
al pa. is offline   Reply With Quote
Old 11-30-2014, 10:22 PM   #7
JWL
I have both Fowler and Mitutoyo (and others) and in the right hands they all do the same thing. I like the Mitutoyo better than Fowler but maybe because I paid so much more for them?
JWL is offline   Reply With Quote
Old 11-30-2014, 10:53 PM   #8
Mike B
I know Fowler used to be good quality, but might want to check to see where they are made now.
I have a set of dial bore gauge made in some eastern country,repeatable, but over all size measurements are off...even worse when I use the spacer, so I have to use my good calipers to double check things, but did save a lot of money, and didn't have to sleep at a Holiday Inn
The wooden box is nice though!
Mike B is offline   Reply With Quote
