Old 11-19-2014, 03:28 PM   #1
4dy
Default Signal Stat 700 wiring diagram
I have searched the net and found lots of info on other models such as the 600 or 900, but I have a model 700 and need a diagram to wire it up and have the taillights used for lights, brake, and turn signals without adding an extra set of light fixtures. I know I may need to change the sockets out. I have also seen a simple trailer adapter with wire IN/OUT to make all light work.
I don't need a solution for another switch since I have the fronts working with the 700 and just need to get the backlights working. Help!
* * * This is for a 1937, but it ended up in the late V8 section
4dy is offline   Reply With Quote
