Old 11-18-2014, 07:30 PM   #1
31 Model A
31 Model A's Avatar
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Default Broke radiator overflow line...........
As you can see in the photo................
How can that be fixed?
Ed
"Bullshit and Brilliance Comes with Age and Experience"
"Hey Lady, ya wanna buy a Grit?"
"If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers
31 Model A is offline   Reply With Quote
Old 11-18-2014, 07:34 PM   #2
crock
crock's Avatar
Default Re: Broke radiator overflow line...........
Put a piece of rubber hose for a splice.
MY PROBLEM CHILD!
crock is offline   Reply With Quote
Old 11-18-2014, 07:43 PM   #3
SeaSlugs
SeaSlugs's Avatar
that would be easiest way...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 11-18-2014, 07:52 PM   #4
31 Model A
31 Model A's Avatar
I can do that!!!!!!
I'm finding that Sarah is no....Virgin!!!!
Old 11-18-2014, 08:03 PM   #5
Joe K
Joe K's Avatar
You don't want a virgin. Those with experience are much more FUN.
Places that repair air conditioners have sleeves that can be soldered. Or bring it to a radiator shop - you could drive there if you don't mind getting your firewall all dirty.
Make friends with the guy and he'll likely fix it while you wait and do it for free.
Give him a ride afterwards.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 11-18-2014, 08:04 PM   #6
mshmodela
mshmodela's Avatar
Hey all part of the fun being the caretaker of these 83+ year old ladies... I keep in mind what caretaking I might need if I'm blessed to last that long...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 11-18-2014, 08:09 PM   #7
SeaSlugs
SeaSlugs's Avatar
Joe K
oh righ forgot about those! rubber hose will work and last for awhile but may be too thick and put stress on the radiator fins. the above mentioned solder job would be the ideal permanent fix.
Old 11-18-2014, 08:15 PM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
It shouldn't be too hard to solder in a complete new tube.
If you want to repair this tube, and looks are important, then you could buy a short piece of thin brass tube from a hobby store and solder it to the inside of the pipe and solder the splice seam smooth. You'd have to clean the inside of both pieces very well so the solder sticks to them as well as the brass splice.
Old 11-18-2014, 08:23 PM   #9
Mitch//pa
so someone duped you into thinking you were getting an 83 year old virgin lol
however you decide to fix it atleast use the hose for a temp fix or youll have a real mess when the fan slings it all over the place
1/4" fuel will work and fit on tight
Old 11-18-2014, 08:30 PM   #10
23hack
Use black plastic heatshrink tubing.
23hack is offline   Reply With Quote
Old 11-18-2014, 08:32 PM   #11
Mitch//pa
i was thinking that also and would be invisible when done with a little paint
Old 11-18-2014, 09:04 PM   #12
31 Model A
31 Model A's Avatar
Thanks gentlemen.................info and advice greatly appreciated!!!!
Old 11-19-2014, 07:53 AM   #13
C26Pinelake
Do you happen to know how it got broken, in that location on the rad, in the middle of the line and a clean break ?
Wayne
C26Pinelake is offline   Reply With Quote
Old 11-19-2014, 08:00 AM   #14
31 Model A
31 Model A's Avatar
Originally Posted by C26Pinelake View Post
Do you happen to know ow it got broken, in that location on the rad, in the middle of the line and a clean break ?
Wayne
Nope!!! But I plan to make sure the lower half is not plug before I slip on a sleeve to join them. I know the upper portion is clear....found out when I put in that quart night before last. I didn't notice it then where the overflow exited from.
Old 11-19-2014, 08:10 AM   #15
31 Model A
31 Model A's Avatar
It's clear..............
Old 11-19-2014, 03:46 PM   #16
31 Model A
31 Model A's Avatar
The plastic sleeve is a bit too small. Have to get a size larger next time out to fix the overflow line. I did get the radiator fluid changed. What came out was quite dark green and heavy. Almost looked like straight Anti-Freeze. A small amount of rust was at the end. Filled it to the baffles.
