Old 11-17-2014, 04:31 PM   #1
steve fritz
Default 1940 Ford Steering Wheel
What is available on the aftermarket for a 40 Ford Delux steering wheel ? I am keeping the original steering column , which fastens the wheel with a key way, and nut , so the wheels that are splined to fit the IDIDIT and GM columns will not work on the original column. I see the splined wheels are also available in 15 and 16 inch diameter, does anybody make the original wheel in the smaller diameters or are they all 17 inch ???
Any ideas or comments from your experience ???
Thanks!
Steve
steve fritz is offline   Reply With Quote
Old 11-17-2014, 04:54 PM   #2
Krylon32
Default Re: 1940 Ford Steering Wheel
Limeworks makes I think a 16 inch stock appearing 40 wheel that mounts on an original column.
Krylon32 is offline   Reply With Quote
Old 11-17-2014, 07:13 PM   #3
1931 flamingo
1931 flamingo's Avatar
Juliano's??
Paul in CT
Old 11-17-2014, 08:23 PM   #4
36tudordeluxe
36tudordeluxe's Avatar
I'll second Limeworks, but be prepared to put in some time in prep if you're going to paint the wheel yourself.
36tudordeluxe is offline   Reply With Quote
Old 11-17-2014, 10:43 PM   #5
okiedokie
okiedokie's Avatar
Vintique 15" wheel will work on original shaft.
okiedokie is offline   Reply With Quote
Old 11-18-2014, 01:13 AM   #6
Dave in WY
Dave in WY's Avatar
Bob Drake Reproductions or Dennis Carpenter sells nice wheels.
Dave in WY is offline   Reply With Quote
Old 11-18-2014, 07:46 AM   #7
47Merc
"Vintique 15" wheel will work on original shaft"
Where do you get them? All the 15" Vintique ones I can find i.e Speedway motors etc, all say they fit a late model GM column.
Can you buy an adaptor to make them fit?
47Merc is offline   Reply With Quote
Old 11-18-2014, 09:04 AM   #8
bluardun
bluardun's Avatar
Vintique make 2 types. First is a reproduction of an original wheel....very nice. They are available thru retail vintage Ford dealers...aka Drake, etc. The second wheel they produce is slightly smaller in diameter and has provisions to fit later steering shafts and turn signals....also very nice. Available at retail stores. They come complete with horn button, and spring.
They are black and will require painting for original colors.
enjoy.
bluardun is offline   Reply With Quote
Old 11-18-2014, 09:39 AM   #9
okiedokie
okiedokie's Avatar
Old 11-18-2014, 09:44 AM   #10
okiedokie
okiedokie's Avatar
Interior > Steering Wheels
Vintique 40 Ford Steering Wheels
From Vintique
40 Ford 15” gloss black steering wheel fits either a GM column or the original Ford column. Excellent reproduction.
Old 11-18-2014, 09:45 AM   #11
okiedokie
okiedokie's Avatar
This was from Parr Automotive in OKC. $283.00
Old 11-18-2014, 12:11 PM   #12
steve fritz
How can the Vintique wheel fit both a splined aftermarket column , like IDIDIT or Flaming River , GM repro's ,etc and ALSO FIT THE ORIGINAL FORD COLUMN THAT ATTACHES WITH A KEY WAY AND NUT????
Steve
Old 11-18-2014, 12:17 PM   #13
Krylon32
The repro wheel I have used several times in the past had an interchangeable hub which bolted in.
Old 11-18-2014, 02:28 PM   #14
19Fordy
19Fordy's Avatar
Now, THAT is a great idea!
Who makes that wheel?
Old 11-18-2014, 05:27 PM   #15
okiedokie
okiedokie's Avatar
Parr has it in their catalog as does Sachse Rod Shop. Both state that it fits both, no hub change. This is the wheel I have. Since I had no reason to see if it fit a tapered shaft with a key, I can't explain how. I really don't want to pull my wheel off right now, maybe you could call either of them and ask. Sachse is 800-495-3904 Parr is 800-654-6779
Old 11-26-2014, 08:44 PM   #16
push_rod
push_rod's Avatar
I just recently bought a used Vintique 15" diameter wheel on Ebay for $127.00.
It was painted bright red (the seller had painted it to match his interior, but said that once installed it did not look appropriate on his Oldsmobile resto-mod). The hub has dual machining (both a taper with the keyway, and the GM splines) and can be installed onto the stock 1940 Ford steering shaft or a later model GM column. My car happens to be bright red (modified!), so I might leave the wheel red... or change the color later to better match my car's interior.
push_rod is offline   Reply With Quote
Old 11-26-2014, 09:39 PM   #17
okiedokie
okiedokie's Avatar
Thanks push rod for clearing that up.
Old 11-26-2014, 09:58 PM   #18
john worden
john worden's Avatar
This is a Vintique wheel. I did not paint the rim because it was such a nice black finish out of the box and I think it will resist wear better than paint.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa.
john worden is offline   Reply With Quote
Old 11-26-2014, 10:57 PM   #19
1oldtimer
1oldtimer's Avatar
Go for the Limeworks wheel.
They also have others to fit the tapered shaft.
http://limeworksspeedshop.com/
1oldtimer is offline   Reply With Quote
Old 11-27-2014, 11:04 AM   #20
TJ
TJ's Avatar
The Limeworks wheel in a stock '40 (16" wheel) looks better than a 15" wheel in a stock 40. What's wrong with using the repo stock 17" wheel on the stock column? Just curious.
