Old 10-22-2014, 12:43 AM   #1
hardtimes
hardtimes's Avatar
Default Intake information Q....
Anyone familiar with or seen a cast iron intake 1+1 carbs. Name on intake is 'Irving Twin Intake' ? Any info available on his intake ? It appears to be reversible, i.e.- two up or two down, but they have to be single throat carbs. A guy that I know showed me a picture of this same make intake with two zeniths attached as an updraft.
hardtimes is offline   Reply With Quote
Old 10-22-2014, 06:04 AM   #2
tbirdtbird
Default Re: Intake information Q....
oi i want that
'31 180A
tbirdtbird is offline   Reply With Quote
Old 10-22-2014, 06:19 AM   #3
ctlikon0712
ctlikon0712's Avatar
Wow, that is really neat. I would like to find one of those also. Looks like it would run Model A or B Zeniths. Thanks for sharing Hardtimes.
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 10-22-2014, 12:40 PM   #4
Rex_A_Lott
I Googled "Irving twin intake" and this thread pops up.
Looks like its for two updrafts, preferably...for the writing to be right-side-up.
Is it for sale?
Thanks for the pic.
Rex_A_Lott is offline   Reply With Quote
Old 10-22-2014, 01:06 PM   #5
Purdy Swoft
Purdy Swoft's Avatar
The runners and manifold look really small. You could probably run model A Zenith,Tillotson or Marvel dual updrafts with it. It looks too small to give full benifit with model B Zenith carbs or most single throat down draft carbs that I've seen. It looks like there would be real restriction at the carb mounting flanges. I've never seen one exactly like that.
Old 10-22-2014, 01:09 PM   #6
hardtimes
hardtimes's Avatar
Is it for sale?
Thanks for the pic.
Thanks guys, for your help !
I just dug this out of storage, because another barner asked if I had a duel alum vortex. I couldn't remember name, having not seen it for many years.
Have never seen another, except in pic from friend. His shown to me with, as said, two zeniths.
YES, I'd consider selling...if you have to have it,eh !
Old 10-22-2014, 01:41 PM   #7
hardtimes
hardtimes's Avatar
Hm, regarding running B zeniths or most single throat down draft carbs....guys mill out runners to size on both carbs and blocks..no
Old 10-22-2014, 02:24 PM   #8
jkeesey
jkeesey's Avatar
That thing would look incredible with dual Detroit Lubricators sitting on top. Talk about setting the period for your engine, boom 1932 only.
jkeesey is offline   Reply With Quote
Old 10-22-2014, 02:32 PM   #9
wensum
wensum's Avatar
I wonder if used as downdraft there might be some conflict with the distributor?
I have twin Stromberg downdrafts and had to resort to a conventional distributor cap as the ears of the original cap came in contact with the carbs
Keith
wensum is offline   Reply With Quote
Old 10-22-2014, 02:40 PM   #10
zzlegend
zzlegend's Avatar
Hum,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,i have some thing that manifold would look good on. Hum.
zzlegend is offline   Reply With Quote
Old 10-22-2014, 02:52 PM   #11
hardtimes
hardtimes's Avatar
Agree ! You'd definitely have something different !
I'm not into updrafts or would be using it myself. I use 2x2 downdrafts, like Winfields , 81 strombergs .
I'm into trading stuff also. What ever happened to horse trading type transactions anyway ?
Old 10-22-2014, 02:55 PM   #12
CarlG
CarlG's Avatar
Originally Posted by hardtimes View Post
... What ever happened to horse trading type transactions anyway ?
The horses were either put out to pasture or sold to the glue factory.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 10-22-2014, 03:19 PM   #13
hardtimes
hardtimes's Avatar
WHAT !!!!!!!!!! Hope not, as I always envisioned the two giant Belgians that I had to work with, as going to Model A heaven to pull BO As out of harms way
Old 10-22-2014, 04:23 PM   #14
Purdy Swoft
It may not be as small as it looks in the pictures.. Yes manifolds and blocks can be milled. Measurments would tell the story of how far it could be enlarged . Cast iron is a real plus. Aluminum manifolds are weaker and can't be milled much and still support cast iron carbs. The Vortex was suppose to have B size runners but ended up model A size, I think that is the reason that it showed no difference in the dyno tests whether A or B carbs werre used. I've got a vortex manifold in my collection but hesitate to ream the aluminum runners. If I ever use it I will likely run the lighter Marvel carbs. If I saw your manifold at a swap meet I would try to latch on to it if I could . I'm into dual updrafts .
Old 10-22-2014, 05:16 PM   #15
Rex_A_Lott
Originally Posted by forever4 View Post
Here's the carburetor for that manifold, FYI.
http://www.ebay.com/itm/Model-A-Ford...-/271643572663
I never saw one with that mounting flange. Thanks for the link.
I'm not yet, but I'm trying to be.. I've never seen one at a swap meet, and I've only ever seen one dual downdraft for a banger.
Old 10-22-2014, 05:21 PM   #16
hardtimes
hardtimes's Avatar
Hey Vince,
Thanks ! The two zenith that I have had on it way long time ago, were zenith 1s. Thankfully, lots better condition than ebay zenith. Have YOU seen this 4 bolt base before, as I've not ? The two bolt base is what has hung on it also.
I know a guy, that I will call..for information. He has a whole wall covered with these (exotic) updrafts. Collects 'things' model a and just hangs them in his garage. Will not sell anything and no one will ever get to put them to use till after he dies with them ! This one will not go into his wall collection, but will be used by someone.
Old 10-23-2014, 09:34 AM   #17
jkeesey
jkeesey's Avatar
The carb in the link is simply an industrial carb built for use on the A motor, chevrolet never had a carb like that. They had small carbs similar to a Model T and in 31 switched to downdraft. It has the 4 holes so it can be mounted the standard way or angled to the side to allow for linkages on a generator or such a unit. Your manifold has the 4 holes for the same reason, but on the manifold I would assume it would be for clearance of the 2 carbs rather than linkages for industrial use.
Old 10-24-2014, 01:28 AM   #18
hardtimes
hardtimes's Avatar
Well that is interesting information, thanks !
I have a message in for a return call from a real knowledgeable old timer, who has a huge collection of Ford carbs and intakes of 20s/30s era. If anyone has some info regarding this intake, I think it will be him. Maybe tomo I'll have something to report.
