Old 09-04-2014, 08:49 AM   #1
1953fords
Default 1953 Ford Special Washers needed
I have attached a photo of the washers needed for installing the hood. I can't seem to find anyone aware of these special looking washers. I checked with Napa, Ace and other online websites with no luck. If anyone has these or know of were I can get them please reply asap. These are for a 1953 Ford Convertible I am nearing completion of restoring.
Thanks ahead of time.
Steve S
215-679-6669
[email protected]
1953fords is offline   Reply With Quote
Old 09-04-2014, 08:56 AM   #2
19Fordy
19Fordy's Avatar
Default Re: 1953 Ford Special Washers needed
Try Restoration Specialties in Webner, PA.
Old 09-04-2014, 09:03 AM   #3
Vic Piano
Vic Piano's Avatar
Have you tried Roy Nacewicz? I don't have his contact info handy but you can Google him.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 09-04-2014, 01:59 PM   #4
charles in east texas
charles in east texas's Avatar
Where exactly do this washers go? Charles
charles in east texas is offline   Reply With Quote
Old 09-04-2014, 03:30 PM   #5
[QUOTE=charles in east texas;940089]Where exactly do this washers go? Charles
O.K. I looked at a couple of cars and it appears that the washers only go on the two leading pivot arms between the arm and the hood body. If worse came to
worse, a person could nurl one side of a washer that had the same thickness.
I also looked at the 2 volume 52-53 books and did not find a drawing indicating
where the washers go or showing a hood hinge. It may be time to contact
Ray Beebe. Keep us posted. Charles
Old 09-04-2014, 03:59 PM   #6
Graeme / New Zealand
Graeme / New Zealand's Avatar
I have Roy Nacewicz magnetic card on the side of my computer box. He trades under Fordbolts.com
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 09-04-2014, 04:17 PM   #7
19Fordy
19Fordy's Avatar
If worse came to
I know how to knurl using a lathe, but am wondering how to knurl a flat surface like that washer.
Just curious.
Old 09-04-2014, 04:52 PM   #8
51 MERC-CT
51 MERC-CT's Avatar
On '49-'51 Merc's. they are called serrated washers
1-1/8" OD. x 5/16" ID. x .100"
PN 356306-7
Used to help in keeping hood hinge to cowl location from slipping.
Not sure how your Ford hinges mount but if you get an equivalent washer
without the serrations you could try what we used to do years ago when even the serrated washers didn't work. Cut washers out of 80 grit sand paper and place grit side to the hinge assy. under washer.
Old 09-04-2014, 06:42 PM   #9
Originally Posted by 19Fordy View Post
If worse came to
Just curious.
If I were doing it here in the sticks of east Texas, I have a wide chisel
that I would use to knurl the washer in a criss-cross pattern. I can't see why that would not work. Charles.
Old 09-04-2014, 07:25 PM   #10
39wdy
Those knurled washers look exactly like the ones used in cowl vents in the earlier Fords. Perhaps that could be a lead for you. Best wishes, Toby Lampert
39wdy is offline   Reply With Quote
Old 09-04-2014, 08:13 PM   #11
joe plumber
Steve S
215-679-6669
[email protected]
I have some but they are off of a f 100
joe plumber is offline   Reply With Quote
Old 09-05-2014, 08:07 PM   #12
itsa52
itsa52's Avatar
These what you are looking for? http://www.mcmaster.com/#serrated-lock-washers/=tlij8t
itsa52 is offline   Reply With Quote
Old 09-06-2014, 01:38 PM   #13
itsa52
itsa52's Avatar
If I had to knurl a flat washer, I would probably hot glue it to something and get after it with a hacksaw or file, and check my artistic eye
