Old 09-02-2014, 08:24 PM   #1
jhaas63
Default using a manual choke like this...is this normal?
I have a 1953 f100 with the stock flathead and fordomatic trans. The truck runs well when its up to about 180 degrees. Before its at about that temp, it kind of stalls a bit from a complete stop like it isnt getting enough fuel. It has a 2bbl holley 94 carb (just rebuilt), new fuel pump and all new fuel lines.
The problem is gone if you pull the manual choke halfway out until it is up to normal operating temperature. Is it normal to have to do that?
jhaas63 is offline   Reply With Quote
Old 09-02-2014, 08:35 PM   #2
Drbrown
Drbrown's Avatar
Default Re: using a manual choke like this...is this normal?
Depending on a number of conditions and settings each engine can be different. I'm up in the northeast and always need to use the choke for a while until the engine gets moderately warm. If you haven't already, hook-up a vacuum gauge and make sure the carb is adjusted to its best settings, and check for vacuum leaks. Good luck.
Drbrown is offline   Reply With Quote
Old 09-03-2014, 02:13 AM   #3
Tom Walker
Tom Walker's Avatar
Do you know if the main jets are the correct size?
Tom Walker is offline   Reply With Quote
Old 09-04-2014, 04:11 AM   #4
A bones
A bones's Avatar
I've yet to begin my current flathead project, however, I can testify that when I learned to to drive dad's '53 Mainline sedan, to take my driving test, that was the order of the day. Full choke to start, half choke to run until warm. Enjoy yer day, Tom
A bones is offline   Reply With Quote
Old 09-04-2014, 10:26 AM   #5
DD931
DD931's Avatar
Sounds pretty normal to me!!
DD931 is offline   Reply With Quote
