Old 08-23-2014, 05:39 PM   #1
harleytoprock
Default Brake rod anti rattle springs
Hello Folks, I have a newbie question regarding the brake rod anti rattle springs.
When installed, is the therory that springs put tension on the rods, pushing the rear rods to the back end and on the front rods the springs push to the front? I'll be installing the wire type springs. Thank you for your help!
harleytoprock is offline   Reply With Quote
Old 08-23-2014, 05:57 PM   #2
Purdy Swoft
Purdy Swoft's Avatar
Default Re: Brake rod anti rattle springs
Yes
Old 08-23-2014, 06:21 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Also, the front springs mount on the front side of the frame bracket, and the rear springs mount on the rear side.
Old 08-24-2014, 07:40 AM   #4
harleytoprock
Got it. Thank you!
Old 08-25-2014, 10:55 PM   #5
Doug in NJ
Doug in NJ's Avatar
In my experience, the wire type springs work a lot better then the flat ones.
The flat ones seem to lose their springiness.
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 08-26-2014, 01:04 PM   #6
Purdy Swoft
I also prefer the 1931 style wire springs and they do work better.
Old 08-27-2014, 05:07 PM   #7
hardtimes
hardtimes's Avatar
Doug
X two ! Keeping in mind that one or other will be more correct ..restoration wise. Function wise best IMO to use wire type. Although, when using repro wire type, I've had to replace broke 'new' once in a while.
hardtimes is offline   Reply With Quote
Old 08-27-2014, 07:31 PM   #8
ericr
ericr's Avatar
in my recollection, this was a reproduction item that for a long time suffered from the typical repro malaise. I used the wire types from out of the gate.
ericr is offline   Reply With Quote
