Old 07-23-2014, 12:09 PM   #1
rrhorton
Default 31 Coupe wire routing query
I need to run a couple of wires from the engine compartment to the interior side of the firewall. What is the best way to route the wires? Can I go through the terminal block opening or will that lead to chafing and shorting? There is a small hole at the left lower corner just above the frame bolt. Can that be used? How is the wire from the light bale to the dome light routed?
rrhorton is offline   Reply With Quote
