Old 07-22-2014, 12:54 PM   #1
FRANK PKNY
FRANK PKNY's Avatar
Default signal lite devise.
I can't seem to remember to self cancel my turn signal devise. Does anyone know if they still make the self canceling style, with the little wheel that runs on the bottom of the steering wheel?
FRANK PKNY is offline   Reply With Quote
Old 07-22-2014, 01:10 PM   #2
40cpe
40cpe's Avatar
Default Re: signal lite devise.
I had the same problem. I can't help with the self canceling, but if you install a Piezo Electronic Tone Buzzer across the terminals of the flasher you won't forget it anymore. They are cheap on ebay or at Radio shack.
40cpe is offline   Reply With Quote
Old 07-22-2014, 01:17 PM   #3
mrtexas
mrtexas's Avatar
http://turnswitch.com/Turnsignal.htm And you can use a microswitch. I hid my microswitch under the shift knob.
mrtexas is offline   Reply With Quote
Old 07-22-2014, 01:30 PM   #4
V12Bill
V12Bill's Avatar
I put a buzzer from Radio Shack on the flasher to ground. My Lincolns have self cancelling if the turn is sharp enough. But for slight turns of less than 45* or lane change on the interstate, it is easy to leave them on. These buzzers are polarity sensitive. Red wire to ground if you are using the stock pos ground system.
V12Bill is offline   Reply With Quote
Old 07-22-2014, 01:46 PM   #5
4dFord/SC
4dFord/SC's Avatar
I had my wife hit me on the head with a rolled up newspaper every time I forgot to cancel the turn signal. Only took 3–4 rides before it became second nature to turn it off. A cheap and effective solution, but unfortunately I now duck involuntarily whenever making a turn.
4dFord/SC is offline   Reply With Quote
Old 07-22-2014, 01:51 PM   #6
deuce lover
deuce lover's Avatar
Here is a pic of what I have on my 36.It has the rubber wheel.Not being reproduced.Often similar ones on EBAY or HAMB where I got this.Make sure it has 7 wires.
deuce lover is offline   Reply With Quote
Old 07-22-2014, 02:28 PM   #7
36Bill
36Bill's Avatar
I found a flasher that has a buzzer in it. Really loud, you will turn it off as soon as you can.
Bill
The best way to have a friend is to be a friend. Howdy Doody
36Bill is offline   Reply With Quote
Old 07-22-2014, 02:42 PM   #8
flatford8
flatford8's Avatar
Thats funny !!! Right turn Clyde !!!
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver…RIP
Old 07-22-2014, 03:01 PM   #9
FRANK PKNY
FRANK PKNY's Avatar
I would be up for murder if I had to have my wife ride with me! LOL Thanks guys a buzzer would work for me.
Old 07-22-2014, 03:16 PM   #10
supereal
supereal's Avatar
Often the problem is that the rubber "tire" on the wheel that rides the bottom edge of the steering wheel has crumbled and fallen apart. Use a large "O" ring to fill the groove, then adjust the switch by loosening the mount clamp and pushing the switch up so the rubber is in firm contact with the wheel.
supereal is offline   Reply With Quote
Old 07-22-2014, 03:23 PM   #11
oldford2
oldford2's Avatar
Bob,
The wheel on mine is pretty hard from age so only cancels 1/2 the time. I will have to find an O'ring that works. Thanks for the tip. John
oldford2 is offline   Reply With Quote
Old 07-22-2014, 03:56 PM   #12
4dFord/SC
4dFord/SC's Avatar
Originally Posted by oldford2 View Post
Bob,
Probably easier to find a newspaper. Just sayin'
Old 07-23-2014, 09:34 AM   #13
gmc1941
gmc1941's Avatar
I also installed a buzzer, but found it was sometimes too loud and adjusted the volume by placing a piece of electrical tape on the opening. And I thought it was my get invention of the year. The Model A group has a turn signal set up which will self cancel after so many seconds and it's adjustable 6 or 12volt.
1939 Fordor Deluxe
1939 Ford Coupe Std
1940 Ford pickup
Nothing in life is to be feared; it is only to be understood.
gmc1941 is offline   Reply With Quote
