Old 07-15-2014, 09:52 PM   #1
31 RPU
Default Nylon Cam Gear
Does someone make a Nylon Cam Gear for a model A?
I have heard they do pretty well in a Model T engine...
31 RPU is offline   Reply With Quote
Old 07-15-2014, 10:00 PM   #2
MikeK
MikeK's Avatar
Default Re: Nylon Cam Gear
I hope not! After a lot of thermal cycles nylon teeth get brittle and snap off in freezing weather. GM had many nylon toothed timing chain sprockets in the '70's and I changed more than my share- some of them twice on the same vehicle! Of course the loading on an A or T cam gear is way less than a V8 with 200 lb springs.
MikeK is offline   Reply With Quote
Old 07-16-2014, 12:16 AM   #3
Logan
Logan's Avatar
I've heard the opposite about a nylon gear In a T. But I don't have any experience with them. I would only ever put an aluminum gear or the bronze set in an A engine.
Cowtown A's
Logan is offline   Reply With Quote
Old 07-16-2014, 10:54 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
I agree with Logan !!! replacing timing gears is a pain. Metal gears should last a lifetime or more. Thats all that I use on mine.
