Old 07-14-2014, 01:50 PM   #1
DougVieyra
DougVieyra's Avatar
Default Passenger side Tail-lite on '28 Phaeton
As I grow older, and immortality is fading away, I am becoming a bit more safety conscious. Hence, I am now beginning to look into adding a second tail lite (passenger side) to my '28 Phaeton. Because it has a large trunk mounted where the rear spare normally would sit, the existing single tail lite is often times not visible.
So I am soliciting information from those of you who HAVE actually mounted a second tail lite to the body of a '28 Tudor or Phaeton (these are different brackets from the '28 coupe / roadster). In particular, the fit of the new cast-iron brackets, to the body. The bracket that I have does not fit the body as well as I believe it should. Is there some grinding / filing that needs to be done to get a proper fit to the body ?
What have others done to fit this bracket to the car's body, lower belt ?
I would be grateful for any help with this question.
DougVieyra is offline   Reply With Quote
Old 07-14-2014, 02:39 PM   #2
Roadster62
Roadster62's Avatar
Default Re: Passenger side Tail-lite on '28 Phaeton
Ther was one on a customers car that looked very nice. It was a year ago and I forget the details, but the original on the left has captive nuts I believe, the added one had long bolts and nuts on the back side. You have to drill through two sections of the rear rail I believe. I'd drill one, fit the bracket and check the alignment, before drilling the other two. Bob
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical.
Roadster62 is offline   Reply With Quote
Old 07-14-2014, 02:51 PM   #3
d.j. moordigian
d.j. moordigian's Avatar
Think about "nutserts"............
d.j. moordigian is offline   Reply With Quote
Old 07-14-2014, 05:13 PM   #4
DougVieyra
DougVieyra's Avatar
Thanks guys. I am aware of the mounting fasteners; however, it is the actual metal to metal fit of bracket base to body surface, that I am actually concerned with. That is where my bracket does not fit closely and firmly to the body. Are there two (or three) different makers of these brackets ? Or is there only one source, and the bracket mounting base must be custom shaped to closely fit the body contour ?
Old 07-14-2014, 05:30 PM   #5
pooch
pooch's Avatar
Try to source one from Australia/ NZ .
It will fit perfectly on the right side.
I drilled my USA left one right through, as I was not sure I would trust the nutserts in an 86 year old single layer of sheetmetal .
Car is a driver, so nuts showing inside was not an issue.
pooch is offline   Reply With Quote
