#1 |
Will a Model B crankshaft work in a Model A block. Any real changes necessary?
#2 |
Other than the obvious (journal/rod diameters) the only other issue I've heard of is a tendency of the rods to hit against the sides of the crankcase. I believe the B block is relieved a bit for clearance at this place.
It is possible to compensate for this. I explored the option but have yet to act on it. Joe K
Shudda kept the horse. |
#3 |
The main beartings will need to be cut down to model A size. You will need model B or aftermarket special connecting rods. If model B rods are used, special rod nuts will be needed or the oil pan will need some minor mods to clear.
#4 |
A quick look to refresh my memory confirms Purdy on this.
See http://www.jalopyjournal.com/forum/t...engine.506451/ Joe K
#5 | |
![]() Quote:
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
#6 |
#7 | |
![]() Quote:
The rods will clear block, but will touch pan..ergo pan dimples, as said. You will have the benefit of larger/stronger rod journals and use any B crank that you wish to do this, i.e.- Ford first edition..without counterweights, right up thru C crank. If I were you, I'd get a copy of member Jim Brierley's book and you will not only have answers to the instant inquiry....but much/much more, IMO ![]() ![]() Last edited by hardtimes; 07-11-2014 at 01:45 PM. Reason: correction...... |
#8 |
The beaver tail crankshaft isn't a mobel B crankshaft. The beaver tail crankshaft was used in 1928 and has the same journal sizes as the later model A crankshaft
#9 |
daveymc29,
I recently did this. Had the mains ground to standard A size and used Snyders B rods which had nuts that did not contact the sump. Also fitted a modern rear seal which I hope will not leak too much. I expect to run this engine in the next month or so. Cheers, Gavin |
#10 |
The oil slinger is a different size and needs to be machined to fit the A block if it is off by just a few thou diameter, thickness and taper it will leak
find a machine shop that has done this or you have you have it machined for a modern seal easier |
#11 |
use ARP nuts, the 12-point kind and they clear the A pan with no mods needed.
