Old 07-07-2014, 07:28 PM   #1
JohninKuranda
JohninKuranda's Avatar
Default Oil to use in Spindle bolts - Australia
Hi
Just hoping that an Australian T'er can suggest a local oil that is appropriate to use in the spindle bolts on my T. Or the viscosity that should be used.
Assistance appreciated
John
JohninKuranda is offline   Reply With Quote
Old 07-07-2014, 07:52 PM   #2
J Franklin
J Franklin's Avatar
Default Re: Oil to use in Spindle bolts - Australia
use a thick oil like 600 gear oil, it will stay in place longer and lube better, use the stuff the suppliers sell and not an extreme pressure gear oil as it tends to be hard on yellow metal. I'll bet Penrite has what you need. Plain old motor oil works just fine also. but needs to be done as the owners manual suggests ( before each journey).
Old 07-07-2014, 07:53 PM   #3
yachtsmanbill
yachtsmanbill's Avatar
Chain saw bar oil seems to be the general consensus up here... seems to stick to the surfaces better than motor oil. I use whatever OFTEN, usually 60 or 70W motorcycle oil. Im anal about oiling tools or whatever and like to spin the vice closed with one finger instead of struggling 1/2 turn at a time. Don't forget the spring shackles, parking brake cross shaft (hidden holes in frame!) and even the brackets the brake rods slide through, even the carb and timer linkages, AND THE TIMER. I usually lubed the whole system every other time out, pretty religiously. ws
" Warning; the following contains content that the anal retentive may find offensive - please skip on to the next posting!"
yachtsmanbill is offline   Reply With Quote
Old 07-13-2014, 10:07 AM   #4
Willie in Houston
Willie in Houston's Avatar
Kangaroo oil might work. The outback certainly has plenty of them. Just pull them off the Kangaroo catchers off the front of the cars and boil them. (this produces oil)
Just joking.
Willie in Houston is offline   Reply With Quote
Old 07-14-2014, 11:37 PM   #5
Karl
Karl's Avatar
I use diff oil 80W Seems to stick really well and easy to get -Karl
Karl is offline   Reply With Quote
Old 07-29-2014, 05:57 AM   #6
A bones
A bones's Avatar
I always dose gear oil with STP.
A bones is offline   Reply With Quote
