Old 07-04-2014, 03:38 PM   #1
Gavin Maitland
Default Frame for rear bumpers on a '30 pickup
Hi,
Any advice on what to next?
I've a restored 1930 pickup and want to fit the rear bumpers that are on the roadsters. I've bought the whole kit from Mac's and everything else I can from Snyders but can't locate any advice or diagrams to create the brackets I'd need to attach to the chassis.
Anything for sale is for the coupes and far too short for the pickup so I gather I'll need a fabricator but without specifications I'm goosed.
Just to ad to the mix, I'm In Scotland.
Gavin
Gavin Maitland is offline   Reply With Quote
Old 07-05-2014, 02:57 AM   #2
juke joint johnny
juke joint johnny's Avatar
Default Re: Frame for rear bumpers on a '30 pickup
Hi Gavin
You will have to use the car brackets from the chassis , then when you have it all fitted up measure where you want the bumper to be behind the bed ,and have the car brackets extended. That is the easiest way. Keep in mind that the bumper obscures the number plate. so you may have to re locate that as well .
If you need the chassis brackets PM me as I have some for sale .
Good Luck with it
John Cochran
juke joint johnny is offline   Reply With Quote
Old 07-05-2014, 10:07 AM   #3
Charlie Stephens
Originally Posted by juke joint johnny View Post
Hi Gavin
Good Luck with it
John Cochran
I solved the license plate problem by mounting it above the tail light like they did in 1932. Note that the license plate illumination glass was on the top of a '32 tail light. I had to modify the bracket slightly to locate the license plate off center because it would interfere with the bed if I didn't.
Charlie Stephens
Charlie Stephens is online now   Reply With Quote
Old 07-05-2014, 10:23 AM   #4
Tom from Drippin'
Tom from Drippin''s Avatar
I hope the sketch attaches and helps.
The pursuit of excellence is healthy and rewarding.
The pursuit of perfection is frustrating, neurotic and a terrible waste of time.
Tom from Drippin' is offline   Reply With Quote
Old 07-05-2014, 11:03 AM   #5
Ron in Quincy
Ron in Quincy's Avatar
We have 2 Roadster Pickups in our club. Both used Coupe- Roadster bumper brackets and regular bumpers.
Even though they do not extend beyond the bed, the bed is high enough that the bumpers would be struck by most cars before hitting the bed. The appearance is also more attractive, and the bumpers do not seem to vibrate.
Ron
Ron in Quincy is offline   Reply With Quote
Old 07-05-2014, 12:34 PM   #6
Tom from Drippin'
Using the extended brackets as per my post #4, the bumpers provide more protection and the 1X3 steel tube attached to the body stands keeps the bumpers from swaying side to side.
Old 07-05-2014, 01:25 PM   #7
CarlG
CarlG's Avatar
Charlie Stephens
I would be very interested to see pictures of how this turned out. Did you use a '32 tail light or just turn the Model A tail light upside down?
(For whatever reason, it's not letting me upload pictures this morning, but mine looks pretty much like Tom's except that mine is a full length bumper like what is on the front)
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-05-2014, 05:32 PM   #8
pooch
pooch's Avatar
If you don't have a fender well , the spare can be tucked up the rear end .
This is my 28, probably similar to the 30 bumpers for fit.
It just sits in there real easy and rests on the crossbar .
pooch is offline   Reply With Quote
Old 07-10-2014, 01:43 PM   #9
Charlie Stephens
Carl,
I put the bracket on years ago but never got around to the license light problem. I took a stock license bracket (repro of course) and cut it and rewelded it. I assume you could either turn the bucket over (maybe a fit problem) or use the '32 bucket that has the license glass on the top (last picture). Pictures to follow in 5 minutes.
Charlie Stephens
Old 07-10-2014, 02:34 PM   #10
CarlG
CarlG's Avatar
Thanks Charlie, as the saying goes, "a picture is worth a thousand words." I now know what I need to do.
Here's the way mine looks right now with the license plate hidden behind the bumper.
Alaskan A's
Old 07-10-2014, 03:27 PM   #11
Fred K-OR
Fred K-OR's Avatar
Gavin, I had a similar problem trying to mount a bumper on my huckster. Same problem, bed to long. So I did something similar to what Tom (#4 above) did.
I had to put on a bumper because the first thing I did after mounting the huckster body on the frame was to back into the garage door frame.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
