Old 07-01-2014, 11:14 AM   #1
CA Victoria
CA Victoria's Avatar
Default Spark and Gas Rod Colar
Does anyone reproduce the collar at the top of the steering column tube that the spark and gas rods travel in?
Tim
Downtown, Ca
CA Victoria is offline   Reply With Quote
Old 07-01-2014, 12:40 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Spark and Gas Rod Colar
Yep, look at any Model A parts catalog (Bert's, Bratton's, Snyder's, etc.) under steering and you will find it. It might be called a bushing.
Old 07-01-2014, 03:16 PM   #3
CA Victoria
Sorry Tom I was not more descriptive.....I was referring to the part welded to the tube with the notches pressed into it. Found out these are not made......Thanks.
Tim
Downtown, Ca
Old 07-01-2014, 04:10 PM   #4
Tom Wesenberg
I would use a somewhat dull chisel to make the notches deeper. You'll have to hold a heavy steel plate against the backside while doing this, or if the steering is out of the car then lay it against some heavy steel when you chisel each notch. I prefer to move the metal, rather than file it away.
Old 07-01-2014, 04:57 PM   #5
JOES31
JOES31's Avatar
Tom
Is the part with the notches flat all the way down or is there a bow in it at the lower part. Mine is flat down to about 2/3 the way down then goes back about 3/16 to the bottom. It tends to make the lever snap down. is this the way it is supposed to be. It is fairly substantial so I can't see how or why anyone would have bent it.
Can the bottom of the lever that goes into the notches be sharpened a little.
JOES31 is offline   Reply With Quote
Old 07-01-2014, 05:05 PM   #6
Aerocraft
Aerocraft's Avatar
The lever frequently has a flat worn into it where it rubs the notches. I have preferred, since the replacement rods are not expensive, to install new control rods. Using a Dremel, the notches can be cleaned up and the system will work as intended.
Gar Williams
Aerocraft is offline   Reply With Quote
Old 07-01-2014, 10:12 PM   #7
Tom Wesenberg
Originally Posted by JOES31 View Post
Tom
The notched plates should be flat. Like Gar, I have also purchased new rods and found them to be excellent.
