Old 06-20-2014, 10:45 AM   #1
mack4759
mack4759's Avatar
Default License Plate Toppers
Our club is thinking about having a license plate topper created with the club logo on it. At regional meets I've seen a few cars with club toppers, but when I searched the Ford Barn threads I could only find one small thread from the early V8 board that didn't help.
Have any of you had toppers made? Who did you go through? Or, if anyone has had experience with a "topper company" who do you recommend?
Thanks in advance,
Robert
mack4759 is offline   Reply With Quote
Old 06-20-2014, 11:05 AM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: License Plate Toppers
Try doing a search here as I remember it was discussed previously.
Google O'Brien truckers, they may be able to help.
Paul in CT
Old 06-20-2014, 11:27 AM   #3
Rex_A_Lott
You might try asking this over on the HAMB. I know they sell a batch from time-to-time. Or maybe PM Ryan, since its his deal.Usually sold out pretty quickly , too. Good Luck.
Rex_A_Lott is offline   Reply With Quote
Old 06-20-2014, 12:15 PM   #4
V8COOPMAN
V8COOPMAN's Avatar
I'm thinking that O'brien Truckers is the outfit that does the HAMB toppers. DD
Click Links Below __
T5 W/TORQUE TUBE
Old 06-20-2014, 01:37 PM   #5
denis4x4
denis4x4's Avatar
Telluride Rotary Club had these reproduced as a fund raiser by a company on the east coast advertising in Hemmings. O'Brian would certainly be another good choice. He did the Georgetown Hill Climb topper. These are not cheap!
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 06-21-2014, 08:05 AM   #6
The Hot Rod Grille
The Hot Rod Grille's Avatar
The small HAMB tag topper is made by O'Brien. Yes, they usually sell-out very quickly when Ryan announces them. It comes in a rough cast finish and requires a bit of sanding/polishing/paint to look like the one below on my '34. Speedway Motors offers several of the larger tag toppers that attach to both license plate bolts. You might inquire as to who manufactures theirs.
Jim
The Hot Rod Grille is offline   Reply With Quote
Old 06-21-2014, 09:35 AM   #7
Farrell In Vancouver
Farrell In Vancouver's Avatar
The trouble with topper for A's, is that the plates hang on brackets from the tops. Later cars supported the plate from the bottom and "toppers" worked out. Seen some excellent headlight bar mounted location plates and a few cool radiator plates, but not so many Toppers that work on Model A's
Farrell In Vancouver is offline   Reply With Quote
Old 06-21-2014, 09:09 PM   #8
Brian SATX
Brian SATX's Avatar
x whatever on O'Brien. They just did a run for our club and they came out well
Brian SATX
Brian SATX is offline   Reply With Quote
Old 06-22-2014, 07:37 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
I had a topper made for my local Model A club. Here's the procedure:
> Make a full size sketch of the topper and indicate where there will be color;
> Find a shop that will make the topper from aluminum;
> Have a proof sample made and iterate it until it meets your expectation. The pattern maker may make producibility changes to your design;
> Be sure to show it to your club for their approval;
> Buy more than your immediate need to accommodate new club members.
Bob Bidonde
Old 06-22-2014, 06:11 PM   #10
mack4759
mack4759's Avatar
Thanks everyone,
It looks like O'Brien Truckers it is!
Rbt
