Old 06-16-2014, 05:40 PM   #1
msmaron
msmaron's Avatar
Default Anyone Carry a Portable Tire Inflator/Compressor?
Looking at carrying one in the A, anyone use one and have any recommendations., Amazon has a lot of them but don't know which is the best for the Model A, with long tours i have wanted to place on win the trunk and I have a cigarette lighter to plug it into for use. All opinions will be great and NO I DONT use a Old Fashioned Tire pump...LOL!
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 06-16-2014, 05:50 PM   #2
1930artdeco
1930artdeco's Avatar
Default Re: Anyone Carry a Portable Tire Inflator/Compressor?
Are you running 12v? If so go to a motorcycle shop as they carry small ones designed for bikes. Since our tires are not mich biggeror actually smaller in some cases they will be fine.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 06-16-2014, 05:50 PM   #3
P.S.
http://www.amazon.com/Wagan-300-Amp-.../dp/B00198G4XO
I have one of these "charger, air compressor, worklight, booster cable" things. It sometimes goes in the Model A. However, it is usually used as a place for Momma to plug in her iPhone charger on a long trip. I have not yet used the air compressor part, and my Model A is still on 6 volts, so the jumpstart part won't help either. The worklight part has come in handy though.
P.S. is offline   Reply With Quote
Old 06-16-2014, 05:54 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
I used to see a lot of spark plug compressors at swap meets, but they don't show up much anymore. Try to find a USA made compressor. I find the far east ones are pretty much junk. My brother bought one from Harbor Fright and it went up in smoke the first time he tried it.
Old 06-16-2014, 06:06 PM   #5
machine girl
Why, if a tube goes flat you are done (unless you plan on breaking down the tire on the side of the road and replacing the tube) carry a spare and a AAA card, low tire stop at a gas station. we can only carry so many extras,that AAA card is the best.
machine girl is offline   Reply With Quote
Old 06-16-2014, 06:42 PM   #6
Wallace
I have nice unit...but it has been worthless...because I don't keep it charged. The unit has to have a full charge in order to boost a dead battery. The air compressor is pretty much worthless....but as an oversized and bulky phone charger, it is excellent.
Wallace is offline   Reply With Quote
Old 06-16-2014, 06:43 PM   #7
Vern
Vern's Avatar
My wifes brand new 2014 Honda Civic Hybrid came with one. Instead of a spare tire, even a donut temporary one, they give you a can of flat fixer and a miniture inflator to plug into the power port. No cigarette lighters these days. The car has the spare tire well, even the place to bolt a spare down, but to save weight they put a styrofoam block in there with the flat repair kit. You don't even get a jack and lug wrench! It's a good thing we have AAA!
You won't be hurt by carrying one on your longer tours and probably will never use it simply because you have it.
Vern is offline   Reply With Quote
Old 06-16-2014, 06:45 PM   #8
barnstuf
I have carried one in my modern truck for years, but mine is useless for inflating Model A tires that have metal stem tubes as there is no room to clamp onto the top of the inner tube valve they are so close to the wheel center. Perhaps they would be OK with rubber stem tubes but my A's have metal stem and there is not enough room.
barnstuf is offline   Reply With Quote
Old 06-16-2014, 06:48 PM   #9
Kevin in NJ
The original pump does fine and you get exercise.
Kevin in NJ is offline   Reply With Quote
Old 06-16-2014, 07:38 PM   #10
C26Pinelake
About the only reason I see for carrying one is a flat tire. I carry the spare in a can in all my vehicles. It will even blow up the tire on the 1932 Chrysler so it must have a lot of pressure. It costs about $ 6 dollars at Walmart and AutoZone.
Wayne
C26Pinelake is offline   Reply With Quote
Old 06-16-2014, 07:42 PM   #11
glenn in camino
glenn in camino's Avatar
I do in my deluxe delivery. It a 12 volt.
glenn in camino is offline   Reply With Quote
Old 06-16-2014, 07:47 PM   #12
Tom Wesenberg
I agree with Kevin, and I carry a hand pump. It doesn't take long to inflate a tire.
In my modern car, I do have one of the small 12 volt electric direct drive pumps, which was made in Chicago, but all the small pumps I've seen for the past 10 years are gear reduction and very noisey and cheaply built.
Old 06-16-2014, 07:55 PM   #13
mshmodela
mshmodela's Avatar
WalMart sells a made in USA hand pump for less than $10. Yes not peroid correct buti
I tested it with 120lbs in my bicycle tires.
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 06-16-2014, 08:16 PM   #14
RonC
RonC's Avatar
http://m.homedepot.com/p/Ryobi-18-Vo...731/203060297/
RonC is offline   Reply With Quote
Old 06-16-2014, 09:03 PM   #15
Growley bear
I removed four tires and tubes from my Model A and installed new tires and tubes; never removed a wheel.
Chet
Growley bear is offline   Reply With Quote
Old 06-16-2014, 09:09 PM   #16
roccaas
roccaas's Avatar
Which one of the Monkees blew up the tire by mouth on the custom Goat. Always thought that was cool (and unlikely).
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 06-16-2014, 10:22 PM   #17
V4F
V4F's Avatar
i carry 2 air pumps (12v) & spare tire in a can . i also have tubless radials . if running tubes your screwed on a flat unless as said you change the tube . you can do that with out taking the wheel off .
V4f
V4F is offline   Reply With Quote
Old 06-16-2014, 11:41 PM   #18
CarlG
CarlG's Avatar
I have one in my PU. Only time I had to use it was to inflate a "very soft" tire on another car while waiting in line before a parade.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 06-17-2014, 11:30 AM   #19
jrelliott
jrelliott's Avatar
Northern Hydraulics sell a good one for use on 12V only and must be attached to the battery as cables too large to attach into cigarette lighter. If you have a flat with the tubes we have on most of the Model A's, how many service stations even carry a true tire patch as most only have the plugs you put in radial tires. Possibly a good tire Shop.
jrelliott is offline   Reply With Quote
Old 06-17-2014, 11:58 AM   #20
msmaron
msmaron's Avatar
NO I'm not using a hand pump and I have an inverter in the car for my cig lighters. I was looking at this one actually...Thank you all for you opinions and they are very valuable to me...
http://www.amazon.com/dp/B0036E9VB6/...I1G2C82W1VRJZS
A7191-Sport Coupe
29 Roadster
29-Town Sedan
