#1 |
I have a solid 29 gas tank that needs the surface removed inside and out. I was told to have it dipped or boiled. Do I need to coat the inside with anything after I have this done?
#2 |
The trouble with coating it is, as they change the formula for gas you don't know if it will attack the coating.
#3 |
if you keep 4 oz. of MMO in 10 gallons of gas, the inside of the tank wont rust
#4 |
what is mmo ?
#5 |
also If you have a tank that is coated and you want to remove coating HOW ?
#6 |
#7 |
That's the problem! In most cases if the coating is failing there is no easy way to get it all off.
