Old 05-31-2014, 08:13 PM   #1
Kahuna
Kahuna's Avatar
Default Flathead timing
Not sure there's too much interest, but here's what I did to be able to check the timing on my engine.
I found that a 5" diameter thinwall tube would just sit in the backside of the
front pulley. I had a shop cut a ring off a bit bigger than 3/8". I then carefully welded the edge of the tubing to the pulley (tubing is about .060 wall thickness).
The outer diameter of the stock pulley is just a tad over 5". I then purchased some timing tape for a Pontiac that had a damper diameter of 5 1/4". I figured that would be close enough for me.
I made sure I had TDC located, installed the tape, then made an indicator that will bolt to the distributor housing bolts. I'll have a complete picture soon showing the indicator
Here it is and I think it'll work well. There's plenty of clearance also
Kahuna is offline   Reply With Quote
Old 05-31-2014, 08:25 PM   #2
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Re: Flathead timing
Nice looking job. I've never painted an engine that color, it looks good. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 05-31-2014, 08:49 PM   #3
Kahuna
Kahuna's Avatar
Thanks Walt
Jim
Old 05-31-2014, 10:16 PM   #4
Ol' Ron
Ol' Ron's Avatar
Good for you, every little bit helps
Old 05-31-2014, 10:27 PM   #5
outlaw
great idea! Thanks for the tip. Bill
outlaw is offline   Reply With Quote
Old 06-01-2014, 07:59 AM   #6
grumpys hot rods
Looks Great !! I like the engine color.
It will be interesting to be able to check the timing with a timing light.
grumpys hot rods is offline   Reply With Quote
